Ford Truck Enthusiasts Forums
-   1994.5 - 1997 7.3L Power Stroke Diesel (http://www.ford-trucks.com/forums/forum170/)
-   -   Dump HPOP question (http://www.ford-trucks.com/forums/1321141-dump-hpop-question.html)
Robbieo11 06-20-2014 04:34 PM
Dump HPOP question
[What does it pump or diesel. Yes diesel is an oil does it pump diesel?
Reason i ask is i am replacing the o rings $1.01 each at international. While it is draining i see motor? Draining out of the ports. Is this an indication there is other issues?
Thanks
In advance
Brain's 97 Diesel 06-20-2014 05:09 PM
HPOP is a high pressure oil pump, that pumps motor oil (not diesel fuel) at high pressure, which is used to fire off your diesel fuel injectors.
Robbieo11 06-20-2014 05:52 PM
Ok got it
Another ? Why was fuel consumption so high 1/4 tank for 10 miles did it just dump the fuel into the cylinders? Oil level is ok i do not see where oil has dropped that much
I assume i will need and oil change now correct?
427 fordman 06-20-2014 10:01 PM
Diesel usage wouldn't have anything to do with the hpop. Are you sure you didn't blow a braided fuel line?
Robbieo11 06-20-2014 10:04 PM
O ya blew sprayed onto the hpop and was bouncing off. Kinda glad it did thefittings on hpop where loose and leaking the return hose is shot drivers side pass side is not much better so trying to find replacements online now
427 fordman 06-20-2014 10:16 PM
I think riffraff has the braided fuel lines. I know they have the high pressure oil lines. You can send Clay an email or call if you can't find them on his site.
427 fordman 06-20-2014 10:20 PM
I believe I have my fuel lines in the shop if you would like. I converted to electric fuel so have no need for them. Of course no guarantees, they had 150k on them, but didn't leak at all.
I don't know if you have enough posts to pm me, but if you are interested and can't, email me. 427fordman at gmail.com No spaces in the address, and at replaced with @. I can send them out monday.
fordpride 06-20-2014 10:43 PM
Driver Side Fuel Line 94-97 - Riffraff Diesel Performance
Passenger Side Fuel Line 94-97 - Riffraff Diesel Performance
