2001-2003 Ford F150 Truck (Except Crew Cab) Power Telescoping Turn Signal Towing Upgrade Mirror Pair
VISIT US HERE FOR GREAT PRICES 2001-2003 Ford F150 Truck (Except Crew Cab) Power Telescoping Turn Signal Towing Upgrade Mirror Pair
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!! http://dgzmd7u6z2by7.cloudfront.net/...1212/large.JPG These replacement UPGRADE mirrors are just what you need to get your truck in good working form again! Specifications: Both LH (Driver Side) & RH (Passenger Side) Specifically designed as UPGRADE bolt-on replacements for Light Duty trucks '08 and up model Super Duty style 3 stud mounting Has the following options: Power upper mirror Turn signal Turn Signal wiring will be plug and play if original mirrors have turn signals. If the original mirrors you are replacing do NOT have turn signals, wire splicing may be required. Dual telescopic arms Textured Black housing Direct replacement upgrades Built to strict quality control standards Instructions included These mirrors are designed to replace the factory mirrors and will install just as the originals do. They make perfect replacements with great upgrades that have good cost savings over the dealer parts. Also fits these models: 2004 Ford F150 Heritage Truck Power Turn Signal Telescoping Towing Upgrade Mirror Pair 1997-2000 Ford F150 Truck Power Telescoping Turn Signal Towing Upgrade Mirror Pair 2001-2003 Ford F150 Truck (Except Crew Cab) Power Telescoping Turn Signal Towing Upgrade Mirror Pair 1997-1999 Ford F250 Truck Light Duty (Under 8500LB GVW) Power Telescoping Towing Turn Signal Upgrade Mirror Pair |
back in stock
