Power Steering Pump Bracket 79 F100 6 cyl
Okay, I am restoring a 1979 F-100 (6 cyl 4.9L) and I want to add power steering. Finding the pump was easy - the bracket not so much.
Does anyone on the forum have a picture of the power steering pump bracket on an F-100 6 cylinder? That would help me get an idea if I can fabricate one. In the mean time I'm still searching for one if anyone has any ideas of where to find one. Thanks, Scott |
1 Attachment(s)
Here's the illustration from the Ford parts catalog.
The illustration at the bottom of the page, "C" is the 6 cylinder bracket. Welcome to FTE, lot's of good people here, plus a few grouches. |
Originally Posted by scottness2
(Post 14382356)
Mike - thank you for the picture. That's perfect. I was hoping it was one piece; it may be safer if I continue my hunt.
Redroad - I am looking to put in the stock pump. I pulled one in great shape off of a 302 but obviously the bracket will not fit. NOw that I know what I'm up against I will definately keep looking for one. Thanks for the help. |
Don't lose the spacer when you pull it
http://i1072.photobucket.com/albums/...ps5f510a2e.jpg http://i1072.photobucket.com/albums/...ps11383460.jpg http://i1072.photobucket.com/albums/...pseba6607f.jpg |
1 Attachment(s)
1978/79 F100/350 300 I-6: There are two P/S pump brackets.
D8TZ-3C511-A .. P/S Pump Support Bracket / Obsolete D8TZ-3A732-B .. P/S Pump Adjusting Bracket / Obsolete No Ford dealer or obsolete parts vendor has either bracket. ------------------------------------------------------------------ Beginning in 1978: Ford changed the P/S pump on everything (except Econolines), it has a plastic reservoir. This pump is a different shape than the steel reservoir pump used 1965/77. P/S pump mounting brackets used 1965/77 with the steel reservoir pump, will not fit the 1978 plastic reservoir pump. The 1965/77 P/S pressure hoses won't fit either, as they thread onto the steel reservoir pump. P/S pressure hose connects to the plastic reservoir pump w/a qwik connect fitting. Plastic reservoir pump used well into the 1990's. |
Redroad. Great pictures. At least now I know exactly what I'm on the hunt for. Thanks for the tip on the spacer too.
Bill - and thanks for the part number verification (and crushing my dream of buying them online). One way or the other I'll find them. |
