Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum41/)
-   -   56 Ford F-series water pumps and donar pulleys. (http://www.ford-trucks.com/forums/1316549-56-ford-f-series-water-pumps-and-donar-pulleys.html)
Outlaw56 05-25-2014 09:24 AM
I have a 56 ford f-100 and 250 with 272 and 292 Y blocks. They both have double 3/8" pulley dampners (C3TE-6316-D, 63/64 truck with two 3/8" belt generator option). Im looking for a double water pump pulley that will bolt on and line up with these dampners. Hopefully it will have the same bolt pattern and shaft hole (3/4").
Is there a pulley or pulleys with a part number I can search for that will be a good match? Im looking for something in the 6 1/4" diameter range to clear the aftermarket generator to alternator conversion sold by John Mummert. It has a 3/4" shaft hole and is 2 3/4" high. The pulley I have now has no number on it to identify it.
I have heard some of the double pulleys on the FE engines are a good swap for this project, but you may have to drill the shaft hole (enlarge) to 3/4".
tinman52 05-25-2014 12:48 PM
I looked though my pile of Y block parts.....no double pulley but several singles. I'm wondering if only the HD truck Y's used the double pulley.
FE pulleys are pretty big, maybe a SBF will work?
Outlaw56 05-25-2014 01:17 PM
What is a SBF pullley, lol?
tinman52 05-25-2014 05:41 PM
Quote:
Small Block Ford 289-302
Outlaw56 05-25-2014 07:34 PM
Im still going to keep checking all my options and this time Im taking a straight edge. If I lay it across the back of the pulley and it measures 2 9/16" to the inside of the hub, its going to be close. Obviosly needs to be set up for 38 pulleys and has to be real close to 5/8" center to center at the bottom of the groove. I will let every one know what I find.
