Ford Truck Enthusiasts Forums
-   6.2L V8 (http://www.ford-trucks.com/forums/forum206/)
-   -   Drone noise (http://www.ford-trucks.com/forums/1316099-drone-noise.html)
CrpssFire 05-22-2014 01:10 PM
Drone noise
2014 F250 6.2 and I put on the Bullydog intake setup. Love the looks of it and the added rumble but on slow acceleration it makes a pretty drastic drone. Im guessing removing the old intake with all its resonators on it is causing this. Anyone else experiencing this and figured out any solutions? Thanks.
GSSF17 05-23-2014 08:43 AM
I had the same experience when I put on the K and N system (I use an AEM dry filter by the way). I put a cheap throttle body spacer on and it fixed the drone sound. I was experiencing it on acceleration just like you. Just my 2 cents. Hope you get it figured out. Good luck
CrpssFire 05-25-2014 08:50 PM
Quote:
Can you go into more detail about what you did with the spacer. Thanks.
GSSF17 05-26-2014 09:38 AM
I installed the Volant throttle body spacer. Prior to that, with the K and N intake, I had an annoying whistle and "hum" (which is synonymous with "drone" here) under accelleration. Installed the TB spacer and the whistle/hum went away. TB spacer cost like 34 bucks. Heck, for that $$$, I think it is worth the gamble to try for you. Can't hurt......
CrpssFire 05-26-2014 12:36 PM
Quote:
Went to Volant website and they just list one of a 2011 Raptor w/6.2. Nothing else listed for a 6.2. I would think it would be the same but can never tell with engineers. Is this what you used? Thanks.
GSSF17 05-31-2014 01:04 PM
Sorry for the delay. I believe I got mine from summit.
here is the link, and if you scroll down it shows fitment.
http://www.summitracing.com/parts/vn.../applications/
