Charge the batteries in that camera!
It's like Christmas when you were a kid isn't it Nick! LOL!!.........except now we have to buy our own presents :'(
Originally Posted by ReBilld
(Post 14472527)
I always said, 'she'll get over it!'
Originally Posted by oldbird1965
(Post 14477720)
The machinist just called me. The motor is done. He still has to do the intake valve seats but I can start on the short block. I will try to get it picked up tomorrow but I don't know how much time I will have for it though cause I just pulled the trailer to a nice little lake. I figured I would get one more trip in before I got the motor back but I guessed wrong
Sounds good Nick. Time to go to work!
When I rebuild the one I tore down the other night, I plan on painting the block and heads something other than black so it will be easier to spot leaks. Something like Ford blue, Ford gray, or the one I'm going with is Ford red. Just something to think about if you haven't already :-X22
(Post 14483801)
Originally Posted by MOOSE_MACHINE
(Post 14484188)
i kinda like the idea of the black so I can't see the leaks ;)
Haha. That is true Glenn. I park on gravel so it doesn't matter as much but it is nice to be able to park on someone else's driveway and not have to worry about it.
I pulled out the injector cups late last night. The riff raff tool worked quite well but I could imagine it being a bit of a challenge inside the truck. I'm planning on cleaning up the holes and installing new cups this am http://i1333.photobucket.com/albums/...psaiyenklf.jpg http://i1333.photobucket.com/albums/...ps9uwyaisn.jpg http://i1333.photobucket.com/albums/...pspymuglzm.jpg |
I didn't realize the cups were that deep. How does the tool actually grab the cup to pull it out?
(Post 14485832)
I finished the cup replacement this morning. Hopefully they seal up properly. All in all I would say that cleaning out the old retaining compound was probably the hardest part of the job.
Here is a pick of the cup puller Glenn http://i1333.photobucket.com/albums/...psmgj83x3b.jpg I used some wire brushes on a drill to clean the bores http://i1333.photobucket.com/albums/...psti0zzvku.jpg After the wire brush I used compressed air to blow them out http://i1333.photobucket.com/albums/...psha7ficpu.jpg Before installing the new cup I cleaned them with wax and grease remover. Sorry I don't have any pics of the retaining compound on them http://i1333.photobucket.com/albums/...pswdzw1z8t.jpg It took two tries on the first cup because I don't realize how far to press it in. Shining a light from the bottom of the head helped to get it figured out but the only way I can describe it is tighten till snug and keep going till tight http://i1333.photobucket.com/albums/...ps6jfp54mn.jpg The finished product http://i1333.photobucket.com/albums/...psay9p4ubl.jpg All ready for rosewoods stage 2's All in all the kit is very well put together and I would recommend it to anyone. It comes with almost everything you need except the cleaning products http://i1333.photobucket.com/albums/...ps1gjyx0c2.jpg |
If the motor is in the truck, how would you clean the hole out without getting stuff inside the motor?
