Twins huh, Nick? Mine turn 9 this fall. And yeah, those candles get bright quick... :-X15
Originally Posted by ColoradoFordBoys
(Post 14612993)
I have been trying to keep a watch on this overhaul because I am in the same boat Just dropped my block off at the machinest today. with .010 pistons from clay. I was curious what piston to cyl bore clearance is because I am seeing .0055 seems to be the recommended standard but my 94 7.3 DI ford service manual is calling for for .0036-.0048?? Just cusious what you did. Another question what did you go with for ring gap?? P.S. Sorry about the war wound!!
Originally Posted by DIYMechanic
(Post 14613699)
Thanks for the info don't worry about the piston to cyl clearance I have the manual so I have the same info he used I'm sure. Were your ring gaps good or did you have to file them?
(Post 14614886)
Thats good news!! Hopefully mine are too. My block is supposed to be finished by the end of the week so I will know soon enough. Another question was your timing cover scored?
(Post 14614943)
No, sorry I should have explained different. Where the LPOP bolts to the timing cover. mine must have gotten trash in the oil. I am thinking of having .010" machined off to clean it up seems like that wouldn't hurt anything? She is in pretty rough shape for 124k miles.
(Post 14615565)
Seems pretty common and I was thinking this would be a good time to address it. Hopefully someone has some idea? Looking at the cover I can't see why taking a little meat off that raised area where the oil pump mounts would effect anything?
It all depends on where it sits on the crank
True but it will just move the oil pump back the amount removed from the timing cover I think I will just look to see where the seal was riding on my harmonic balancer and if I have room on the sealing surface I'm going to go for it. I am pretty sure the engine would have to come back out to fix it later and I don't want to do that?
K fellas. I made a bit more progress it today. Slapped a little paint on it
http://i1333.photobucket.com/albums/...ps0zpdppyt.jpg Then I thought to myself. Gee did I torque the oil pickup bolts??????? $#/+. So off with the pan and while at it I removed the front cover as well to get the one intake bolt in that is behind the hpop res. oh well. Could be worse. I could have put it together without torquing it and pooched my motor. For the record it was torqued. I also got a bit creative with the oil cooler. I don't have the luxury of a press so I made do. It worked well http://i1333.photobucket.com/albums/...psfwitimkp.jpg Yes that's a ratchet strap. And yes I used it to pull the peices together. Rolled the motor over an started to put some stuff on top http://i1333.photobucket.com/albums/...psc7oxurk9.jpg http://i1333.photobucket.com/albums/...psxcwoc1vm.jpg I put the intakes on, the T-500, and got the injectors in. It was a good day. |
Looking pretty good man!
Very nice!! Those kinds of little things (like the oil pickup bolts) will absolutely drive you nuts if you don't follow up on them. You did the only thing you could do by pulling it apart to check. Looking good!
