Uh-Oh, I think Hal is intercoursed
So I go to start Hal a couple days ago and the starter wouldn't turn the engine over. The starter sounded OK but it sounded like the engine would start to turn over but then just stop. So must be the started I thought.
Just put now put on a new starter and when I went to turn the engine over there was a loud BANG and violent shudder. I instantly turned off the engine and looked under the van to see oil pouring out. http://larry.wvnet.edu/~van/pics/oh-oh-m.jpg Got the drain pan under there but not soon enough. One advantage of having cats. Big bags of cat litter. So does this mean what I think it means (new engine needed)? |
Oil pouring out from _where_? Definitely Not Good (tm) tho theoretically it could be the oil filter? Yer gonna have to look. Maybe a rod... Sorry for your loss.
Sent from my iPhone using IB AutoGroup |
It's leaking out of the space just aft and above the crossbrace. Oil filter looks fine.
Yeah.. Hal is definitely in trouble.
rip hal :(
Uh oh, that isn't good! Really sounds like you and Tim have the same lousy luck.
Like the play on words with "intercoursed". :D |
Hydro locked start and a rod through the block? My condolences WVVan..........
Originally Posted by Tom
(Post 14315993)
What a bummer, WVVan. I'm guessing you have enough work in the rest of the van that it'll be worth your while putting in a new engine. Good luck finding the right source for a tight rebuild, or a really good used engine. I'd suggest a conversion to a 4.6 but fear that it'll be too complex with wiring harnesses, computers, etc.
And yeah, being a cat owner has been handy, like the time I screwed on an oil filter with the gasket from the old filter still stuck on the mounting surface. But it was much easier for me to laugh off the problem because the cost was only a few quarts of oil.... Best wishes for Hal's resurrection.... George |
BUMP!!!
Any update? |
Poor guy is probably crying about this--I would be after all the amazing work refitting he's done to this van. :(
just do a motor swap it is anoying but at least the van would be runningn again and reliable?
Originally Posted by tims01
(Post 14340264)
Good luck to you, WVVan; you have been such an asset to our FTE van community. Note that I am also a (road) bicyclist and the prez of a big bike club in Michigan. Big vans rule for carrying bikes and people and stuff... George |
Isn't it about time Hal info was updated?
Missing all those updates, upgrades, and pics of carefree supervisor. |
x2 on the update, read all WVVan's other threads on putting Hal together, hate to see this "little" road block louse up a good thing
