Ford Truck Enthusiasts Forums
-   2004 - 2008 F150 (https://www.ford-trucks.com/forums/forum24/)
-   -   Need advice on check engine light (https://www.ford-trucks.com/forums/1312537-need-advice-on-check-engine-light.html)
stnlycup 05-01-2014 09:00 PM
'04 FX4 5.4
Backfired when I was starting it yesterday and shortly after the engine light came on..Not sure of the number of the codes, but 2 are "lean bank 1&2 MAF sensor" and the other 2 are for "lean bank 1&2 O2 sensor"
Im thinking the backfire clogged the MAF sensor. I tried to clean it with brake clean but it didnt seem to help.
Wondering if I should spend the $125 on a new MAF sensor in hopes thats the problem..or is there a better way to narrow it down?
Thanks in advance for any input
VTX1800N1 05-02-2014 08:51 PM
Originally Posted by stnlycup (Post 14310529)
'04 FX4 5.4
You should now that you used brake clean on it. Use only MAF sensor cleaner on the MAF sensor.
stnlycup 05-02-2014 09:02 PM
hmmm...didnt know there was such a thing....guess im making a trip to the parts store in the morning
JWC 3 05-02-2014 09:06 PM
I will have to disagree with you on that . I have used brake cleaner for Many years on Maf sensors .:-X22 I also use it on other electronic parts with good results . I just removed and cleaned out the under dash fuse / relay block on my 04 Mounty after a soda found it's way into it , Ask My Wife how that happened !
VTX1800N1 05-02-2014 09:16 PM
You take your chances, but brake cleaner can damage some of the insulating materials used in electronics. They make MAF cleaner specifically for that component.
JWC 3 05-02-2014 09:31 PM
Never had an issue :-X22 . All we use at the shop I work at now ( for 14 years ) used it at other shops for cleaning in the past . My brother in law in Chicago uses it also , he works for an electronics company . He told me about using brake clean . :-drink
