Ford Truck Enthusiasts Forums
-   Ford Truck Parts for Sale (http://www.ford-trucks.com/forums/forum235/)
-   -   Vision 81 wheels Toyo M143 245/70R19.5 Tires (http://www.ford-trucks.com/forums/1309863-vision-81-wheels-toyo-m143-245-70r19-5-tires.html)
BWST 04-16-2014 10:20 PM
8 Attachment(s)
Set of 4 Toyo M143 245/70R19.5 Tires mounted on Vision 81 Heavy Hauler 19.5"D x 7.5"W aluminum wheels. I used these for two seasons from April to October to carry my camper. They were mounted on my 2000 F350. Deal includes lug nuts, but no center caps.
Tires are 33" diameter, equivalent to the 285/75R16's I run in the winter. Stock tire diameter for the F350 is 31", so these are one size up. They will fit a non-lifted F350 truck without rubbing on anything.
Tires have 12/32's tread left (16/32's when new, so 75% left). These tires are heavy duty commercial H-rated, 4805lbs single, and can be regrooved. Wheels are rated at 4500lbs each.
bolt pattern is 8x170mm. Center bore is 124.9mm. Lug nuts are 14mm x 2.00
