Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum41/)
-   -   installed Soffseal door seals today - not good - any tips?? (http://www.ford-trucks.com/forums/1309803-installed-soffseal-door-seals-today-not-good-any-tips.html)
DW SD 04-16-2014 06:49 PM
1951 Ford, F1. Seals seem like a quality product and fit well. But....
The door is incredibly hard to close!! And the strikers are adjusted all of the way out.
I installed the portion between the lower 2/3rds of the door and the A-pillar, first (they come in 2 sections.) That seal caused most of the interference. The other being the top 1/3 of the a-pillar, over the top of the door and down to the bottom rear corner. Maybe it is just the portions being pinched between the hinge halves?
Anyone think they'll loosen up after being squeezed for a while?
I'm disappointed. I will call Soffseal tomorrow. Their website says 100% satisfaction. At this stage, I might as well have welded the door shut. :-huh
topmoo 04-16-2014 06:54 PM
Soffseal is a really good outfit and everything that I have gotten from them has been great, but I haven't gotten my door seals yet. I hope that they take care of it for you if it is a problem with their product. I will be watching to see what happens, I am ready to order them.
DW SD 04-16-2014 07:15 PM
thanks for the post.
I don't think it is the product quality. If anything the seals just seems too thick.
Have you found in the past that they form a bit and fit better?
Doug
B/B ford 04-16-2014 08:02 PM
I don't know about soft seal but mid-fifty sells hollow door seals just for this problem.
topmoo 04-16-2014 10:21 PM
Doug
I have only used their products on the woodies that I built or worked on. All wooden doors that I built so I was able to leave enough room for the weather strip and using their universal product so there is really no way to judge. I never had any complaints with it though. I was planning on using their seals on my '52 so please let me know what they tell you when you talk to them.
Jasonnoel 04-16-2014 10:41 PM
Door seals are usually too thick. I buy some universal stuff in 50 lengths and use it rather than fighting and slamming doors all the time. And a poorly adjusted or not working latch/strike plate will trick you into thinking seals are too thick also. So check it all out.
bjmayberry2 04-17-2014 09:20 AM
Quote:
Got a part number on what you use?
DW SD 04-17-2014 12:12 PM
I heard this from mid-fifties. Also, I will call Soffseal later today. I read on a tri-five board that many use a heat gun to allow the seals to deform and that it is common for soffseal seals to be too large.
Hi Doug,
We do have hollow door weather stripping, but it already has molded corners specifically for 1953-55 & 1956 doors. You may be able to make them work, but I am unfamiliar with F1 doors, so don't want to point you in the wrong direction. You should give Classic Haulers a call as they specialize in just 1948-52 F1's and may have more insight to your situation. You can reach them at 877-252-1948 or visit classic-haulers.com.
We also carry hollow domed weather stripping, that is not preformed. See our part number 3106-DM. I have attached a picture of a cross section for reference.
Please let me know if you have any questions.
Thank you,
Jesse
Mid Fifty F-100 Parts
DW SD 04-17-2014 05:03 PM
I called Soffseal several times today. No one answers. I left a v/m for the sales department asking them to please call me (there is no support option). No word back.
Doug
jonnireb 04-17-2014 10:31 PM
Door seals
I used the hollow seals from Mid Fifty, and they allowed the door to close easily. However they didn't seal quite as well as I wanted (wind noise) so I glued a then flat softseal to the cab door opening so the two seals come together when closed. It stiffened the door closing a bit, but not excessively so, and it quelled the wind noise.
pineconeford 04-18-2014 07:52 AM
I started a thread about this a couple of weeks ago. Had the same problem with my new seals and I haven't bought replacements yet.
I'll be following this to see if SS has any response.
Tom
fordf5 04-18-2014 09:25 AM
I just ordered the set from MACS but it will be a looooong time before I can see how they fit.
.....Roger
DW SD 07-01-2014 01:13 PM
A few months later, I'm real disappointed with the seals. The rubber quality seems great, but I have to slam the CR@P out of the door to try to make them close all of the way. The seals are just very dense. I tried setting the truck in the sun, using the heat gun, etc. I might have been able to make them fit 5% better. Barely perceptible improvement.
I talked to the folks today at Steele rubber who are sending me a sample kit of their half round hollow seals. Likely, I'll be cutting most of these out and replacing with something from Steele. Quite frustrating process. I plan to possible save the parts which are molded under the door hinges.
Doug
underthebridgejim 07-01-2014 03:42 PM
Your not alone Doug, I have been running without door seals for two years now. My doors close tight, and I rarely drive on the freeway where noise would be a problem, or in the rain so I'm happy without them.
DW SD 07-01-2014 03:45 PM
Hi Jimmy,
I just got my AC working and do drive on the highway. I'd like to have working seals. thanks for the empathy.
Will update when I have the Steele samples in hand.
thanks,
Doug
