grill surround replacement
whats the easiest way to access bolts to remove grill shell ? or , how do you do it ?
thanks |
No tricks... remove the grill inserts and a shot of PB Blaster (or equivalent) the day before. Then undo the bolts.
Why the question? It's rather a simple task to generate a question about how to do it.... |
1/4" nut driver in one hand, cold barely soda in the other. Piece of cake
79 f150. remove grill inserts ? i dont see how to get to the bolts. the ones on each side by the headlights. three on each side . the bolt heads are on the backside of the grill.
Originally Posted by supertuff
(Post 14259473)
1 Attachment(s)
1/2-inch combo wrench and 1/2-inch socket on a ratchet...
.......It goes without saying but here's a visual: http://igetpaidonline.biz/wp-content...05/caveman.jpg |
On top of this question, I've noticed the round light grills (pre-79) and the surrounding area look like they would bolt right up to a 79 as a direct replacement. I like the rounded look a bit better and I need to replace anyways. Just direct swap?
Originally Posted by gfburke
(Post 14260205)
Otherwise, very low on the difficulty meter... about a 2 out 10. |
(Post 14259473)
Originally Posted by HIO Silver
(Post 14260340)
Not quite direct because of different headlight buckets which, IIRC, mount in slightly different locations.
(Post 14260735)
Right on. So finding a 77 to strip, just grab all dat up in there eh.
