1977 F250 Crew Cab 4X4 highboy 2-owner, 111K original miles
I'm actually the third owner...
Good running truck, mechanically sound. Cab has rust in the front floor pans ( replacement pans included), all doors have rusty lower corners, some rust in the roof. Front clip and tailgate are rust free, had been replaced in the past. Bed is rusty on the outside, ok on the inside. Door panels are nice, rear seat is perfect, front seat is so-so. Dana 60 front axle, open knuckle, disc brakes, kingpins, low pinion, 4.10:1 ratio. Dana 60 rear also. Original ac cab. Power steering, power brakes, all fully functional (except a broken brake line that I plan to replace right away). 351M engine runs well but kinda idles fast, 4-speed NP435 trans/clutch is good, NP205 divorced transfer case works as it should, 4x4 fully operational. Email for pics or more info. I'm in Union WV 24983 |
Can you shoot me a pm, I would like some pics!
Thanks |
Pics to dharmabum@comcast.net
Will it make a drive or does it need to be towed any distance? |
pics to animal70X7@sbcglobal.net, please.
