How Do I Remove A-Pillar Trim?
How Do I Remove A-Pillar Trim...driver's side 2000 Expedition. Thanks.
Lift upward while pulling it out.
2004 trim removal
Trying to do some work on my auction buy (2004 Expedition XLT) Would anyone know if this would be the same procedure to remove the pillar trim on a 2004 Expedition? trying to get the trim off behind the "o sh#t" handle looks like some kind of bolt on either end of the handle once you remove the little plastic "hole covers" but i don't see a nut or anything that a deep socket can get a bite on? Can't seem to find the proper search terms to find anything. Thanks in advance for any help.
Phil:-drink |
Did you look in the hole with a light? I think they might be torx screws.
On mine it looks like really small hex bolts, almost looks like pins.. My smallest socket available in my set is 6 mm, and it was too big. Might be 4 or 5 mm, or maybe 1/4". I couldn't be bothered to go inside to get more tools, since my job was on the C pillar and I was just gonna pull the headliner down a little and I was able to get the job done without removing it.
If it's 1/4", that should be the standard size of the hex drive on screwdriver bits, so you may be able to use that. I think the trim will come off easily once the handle is removed, but can't say for sure as I ended up not removing mine. :) Edit: Well, just did the math. 1/4" is 6.35 mm so definitely not that. I'm on metrics, so I regularly mess up my inches... :D |
Originally Posted by alloro
(Post 15032250)
Originally Posted by Skauber
(Post 15033217)
If it's 1/4", that should be the standard size of the hex drive on screwdriver bits, so you may be able to use that. I think the trim will come off easily once the handle is removed, but can't say for sure as I ended up not removing mine. :) Edit: Well, just did the math. 1/4" is 6.35 mm so definitely not that. I'm on metrics, so I regularly mess up my inches... :D Thanks again guys!! |
https://cimg1.ibsrv.net/gimg/www.for...15463bc293.jpg
OK this was tucked up behind the the trim?... This was a police SUV and they didnt spend a lot of time removing unneeded stuff when they sent it to auction.- part of what I was doing is taking out the spot light post. But this has one wire and heads into the dash (I will back track ASAP) looks like some kind of Transponder maybe? ANY thoughts some kind of standard sensor maybe? all thoughts are appreciated. |
Could be an antenna for a remote starter, an alarm, a keyless entry, or something like that.
found all kinds of stuff
Well on my way to follow the mystery wire, I found the speaker for the police radio behind the dash with a few zip ties holding it in.
https://cimg6.ibsrv.net/gimg/www.for...0cd0fc2d17.jpg and when I got to the end of the receiver/transponder looking thing it was not connected to anything. so I guess I'll hang onto it just in case. https://cimg9.ibsrv.net/gimg/www.for...292a8a3eaf.jpg ok well I am learning more about interior trim removal then i ever wanted to know.... and found yet more unexplained stuff (see next post) found a cord that goes even deeper into the dash. |
Not sure .. look familiar?
https://cimg3.ibsrv.net/gimg/www.for...28878a06fc.jpg
https://cimg7.ibsrv.net/gimg/www.for...d622faf3ea.jpg sorry if i went off in a different direction than the original post! chasing shiny:-X19 things! |
That last picture of the cable with SKN6365A on it. That's for a Motorola hands-free cell phone holder/charger kit.
Maybe that antenna was an booster antenna for the cell phone. Motorola OEM Mobile Phone Car Holder for Moto T720 |
Good call, I was able to remove two more cables out last night, The one with the number on it and an mini antenna type cable, looks like the sheriff had a hands free/charging motorola kit set up in the truck and when they sent it to auction someone in maintenance went to town with wire cutters. The good news is I got the trim off as requested, the bad news is I had everything so taken apart It just made sense to take out the stock cd/cassette radio... now I have to buy a nice double din size replacement , damn shiny things. Thanks for the ideas and thoughts.
flip - I see you are in WA. One thing to be mindful of with trim work is, if possible, work on this stuff when the interior of the car is not freezing cold. A lot of these snaps and interference fits can break in the cold. It is much more forgiving when warm.
Originally Posted by alwaysfords41
(Post 15036754)
