Ford Truck Enthusiasts Forums
-   Ford Truck Parts for Sale (http://www.ford-trucks.com/forums/forum235/)
-   -   97 F350 CCLB Partout (http://www.ford-trucks.com/forums/1307360-97-f350-cclb-partout.html)
Oscello 04-03-2014 11:19 AM
I have a 97 F350 Crew cab long bed 4x4 that I am parting out. The front axle will be going under my F250 but the rest of the truck is for sale. It has a 460 motor with about 260k on it but it seems to start and drive just fine. The trans is a jasper e4od but I am not sure of the mileage. The fluid is bright red and it seems to work fine. I have not personally driven the truck fast enough for it to shift, but it was taken off the road about a month ago due to a blown brake line. The transfer case is a Borg Warner 4407 but I will need the yoke for the front drive shaft. I may just swap the case or replace the yoke with the one from my 250.
Engine - $250 (for an extra $100 I'll include the computer and harness)
Trans - $350
T-case - $250
XLT Tailgate - $50
Doors - $25ea
Seats - $20ea
Cowl - $20
Metal Body piece under Grille - $20
Plastic Header Panel - $20
Feel free to make an offer. If you see anything else you need please let me know.
http://www.ford-trucks.com/forums/pi...ctureid=152646
http://www.ford-trucks.com/forums/pi...ctureid=152647
http://www.ford-trucks.com/forums/pi...ctureid=152648
http://www.ford-trucks.com/forums/pi...ctureid=152649
http://www.ford-trucks.com/forums/pi...ctureid=152650
http://www.ford-trucks.com/forums/pi...ctureid=152651
fordka 04-03-2014 12:32 PM
If the cab comes off im interested in the cab cross member
danr1 04-03-2014 07:07 PM
Where are you located and what would kinda price on all of its tailgate hardware including the inner cover plate? (Everything but the tailgate itself)
Feel free to PM me.
Oscello 04-03-2014 09:16 PM
The truck is in Great Mills, MD.
Oscello 04-03-2014 09:20 PM
I will look into the tailgate hardware this weekend and respond to your pm.
Oscello 04-06-2014 12:03 PM
Dan1, you have a PM.
Fordka, ill let you know when the cab comes off.
Oscello 04-09-2014 09:32 AM
Bump
XLT Tailgate - $50
Doors - $25ea
Seats - $20ea
fr8train2 04-10-2014 12:41 PM
how is the back drivers door is rusted or dented in anyway and i might be interested in some other parts also thank you very much
Oscello 04-10-2014 05:05 PM
Well, I tried to get a picture of the bottom side but that door does not open. I pulled the door panel but i still could not get it to open.
The door has some rust on the bottom and a small dent. If you are still interested I will mess with it some more.
http://www.ford-trucks.com/forums/pi...ctureid=153935
http://www.ford-trucks.com/forums/pi...ctureid=153936
bozzo152 04-10-2014 09:10 PM
how much for the cab
Oscello 04-10-2014 09:41 PM
If you want the cab its yours for $150, maybe cheaper if you help pull it. Its basically scrap, the floor is rusted out and it has been patched with a tow away zone sign on the driver's side.
http://www.ford-trucks.com/forums/pi...ctureid=153952
fr8train2 04-11-2014 05:05 AM
thank you for looking but its about what i have trying to find alittle better and agin thank you
mrrish79 04-13-2014 08:36 AM
Can't tell in the picture-does it have the gauge cluster with a tach?
Oscello 04-13-2014 06:53 PM
It does not have a tach. Also to answer your PM, the drivers door panel has been drawn on with a black sharpie and the soft arm rest on both of them is cracked.
mrrish79 04-16-2014 12:27 PM
Thank you!
