2002-2007 Ford F350 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgr
VISIT US HERE FOR GREAT PRICES 2002-2007 Ford F350 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!! http://1aauto-images.s3.amazonaws.co...01095/main.JPG These replacement mirrors are just what you need to get your vehicle in good looking form again! Specifications: Comes as a PAIR Fits both LH (Driver Side) & RH (Passenger Side) Power operation Heated Dual Arm Dual Glass Manual Extending Light Smoked Turn Signal Lens with Clearance Light Textured Caps Retrofit 2008 and Up Style Replaces dealer part numbers: 5C3Z-17683-EAA, 5C3Z-17D743-BAA, 5C3Z-17682-EAA, 5C3Z-17D742-BAA, 5C3Z17683EAA, 5C3Z17D743BAA, 5C3Z17682EAA, 5C3Z17D742BAA 180 Degree Swing 10 Hole, 7 Pin Plug Direct replacements Built to strict quality control standards These mirrors make great replacements and have good cost savings over dealer units. Brand NEW fitting for the following years and models: 2002-05 Ford Excursion Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair 2002-07 Ford F250 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair 2002-07 Ford F350 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair 2002-07 Ford F450 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair Special Note: This mirror is designed to replace an original mirror with these exact options. If you do not have the options listed, there is a possibility that this mirror may not function properly. 1 Year Warranty This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. This part replaces: OE #: 5C3Z17683EAA, 5C3Z17D743BAA |
Need to ask a couple of questions for install on my 2002 Execursion
Originally Posted by 1ATony
(Post 14055954)
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!! http://1aauto-images.s3.amazonaws.co...01095/main.JPG These replacement mirrors are just what you need to get your vehicle in good looking form again! Specifications: Comes as a PAIR Fits both LH (Driver Side) & RH (Passenger Side) Power operation Heated Dual Arm Dual Glass Manual Extending Light Smoked Turn Signal Lens with Clearance Light Textured Caps Retrofit 2008 and Up Style Replaces dealer part numbers: 5C3Z-17683-EAA, 5C3Z-17D743-BAA, 5C3Z-17682-EAA, 5C3Z-17D742-BAA, 5C3Z17683EAA, 5C3Z17D743BAA, 5C3Z17682EAA, 5C3Z17D742BAA 180 Degree Swing 10 Hole, 7 Pin Plug Direct replacements Built to strict quality control standards These mirrors make great replacements and have good cost savings over dealer units. Brand NEW fitting for the following years and models: 2002-05 Ford Excursion Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair 2002-07 Ford F250 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair 2002-07 Ford F350 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair 2002-07 Ford F450 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair Special Note: This mirror is designed to replace an original mirror with these exact options. If you do not have the options listed, there is a possibility that this mirror may not function properly. 1 Year Warranty This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. This part replaces: OE #: 5C3Z17683EAA, 5C3Z17D743BAA What is the best way to contact you? I would like to install these new 08 style TT mirror on to my 2002 excursion but not sure if they will work. I currently have paddle style mirrors with power adjustments, heat and signals. Will these features work with the new replacement mirrors? What about the clearance/running light? Thanks Michael |
Originally Posted by mblaksley
(Post 14083961)
Thanks Michael These mirrors would be a direct plug and play replacement for the ones that you have. They have the correct plug ends on them. 2002 Ford Excursion Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair at 1AAuto.com Thanks, Tony |
Thanks Tony, I will order them up. Will the running lights work on the 2002 Excursion?
Michael |
(Post 14085877)
Michael |
