Radio issues 2008 Expy
I have a 2008 Expy the radio w/o nav keep reseting Text reading "sirius ready" turning off and on and cd changer keeps cycling??? I pulled the fuses to try and reset?? batt next?
Yeah, I would try that. Sounds like a glitch in the radio. If that doesn't work try putting the radio into test mode.
Summarized from the Ford Service Manual: Speaker Walk-Around Test: NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM). 1. To enter the speaker walk-around test, simultaneously press and hold the audio unit preset buttons 3 and 6 for approximately 3 seconds, then release. 2. The speaker walk-around test applies sound to each speaker for about 1.5 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR. Audio Unit Self-Diagnostic Mode: • NOTE: Always document and clear DTCs and carry out the audio unit on-demand self-test again. 1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode. 2. To exit the audio unit self-diagnostic mode, turn the key or the audio unit to OFF. 3. The audio unit self-diagnostic mode has 5 tests available: • Preset Button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll through the DTCs stored. Refer to the Audio Unit DTC Index. If the system is OK, SELF PASS will be displayed. • Preset Button 2 = View/Clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the Audio Unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed. • Preset Button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting. ** Perfect for testing antenna types and position changes. ** • Preset Button 4 = Software level query. This test queries each audio system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level. • Preset Button 5 = DISPLAY TEST. This test will light all the audio unit display segments for 5 seconds. When the test is complete, DISPLAY TEST is displayed on the bezel. 5. To exit the self-diagnostic mode, press the power button on the audio unit or turn the key to the OFF position. Audio Unit DTC Index: DTC - Description - Action B1317 - Battery Voltage High - CHECK the charging system. B1318 - Battery Voltage Low - CHECK the charging system. B1342 - ECU Is Faulted - CLEAR the DTC. CARRY OUT the self-test. If DTC B1342 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility. B2406 - Audio Disc CD Player Internal Fault - CLEAR the DTC. CARRY OUT the self-test. If DTC B2406 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility. B2477 - ECU Configuration Failure - CLEAR the DTC. CARRY OUT the self-test. If DTC B2477 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility. REFER to Section 415-01 . TEST the system for normal operation. B2924 Audio Button Stuck INSPECT the audio unit for a stuck button and REPAIR the concern, if possible. CLEAR the DTC. CARRY OUT the self-test. If DTC B2924 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility. B2965 - Audio System Speaker Circuit Fault - See Ford Factory Service Manual for troubleshooting steps |
My Explorer did things very similar
A few days later, the truck would not start - battery was dead Got a new battery and symptoms went away. Seems a weak battery can cause strange things Easiest thing is to swap out with a known good battery before you buy another. |
