2000-2004 Ford F250 Truck Super Duty 4WD Front Brake Pad & Rotor Kit Semi-Metallic for Models with 1
VISIT US HERE FOR GREAT PRICES 2000-2004 Ford F250 Truck Super Duty 4WD Front Brake Pad & Rotor Kit Semi-Metallic for Models with 13" Diameter Rotors
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES!!! http://1aauto-images.s3.amazonaws.co...00660/main.JPG This front brake rotor & pad set is just what you need to get your vehicle stopping in good order again! Brake Pad Specifications: Professional Grade SEMI-METALLIC Disc Brake Pads 4 Piece FRONT brake pad set Includes shims Direct replacements Brake Rotor Specifications: Comes as a PAIR Fits LH (Driver Side) & RH (Passenger Side) FRONT Replaces dealer part number: F81Z-1125-DA, F81Z1125DA Fits 8 Lug Wheels 13" Diameter Vented Rotors This brake rotor & pad set makes great replacements and has excellent value over the price of a dealer brakes. Wear and Tear This item is backed by a warranty against defects in materials and workmanship under its intended use. The warranty does not cover normal wear and tear. Please keep your invoice for proof of this warranty. 1 Year Warranty This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. |
