I found a couple of pieces yesterday while inventorying bolts. First is a heatshield for the right side of the front harness where it comes out under the A/C casing. It may be peculiar to 460 powered trucks as it sits sideways between the wiring and the engine.
https://cimg7.ibsrv.net/gimg/www.for...d6fce81b7d.jpg https://cimg8.ibsrv.net/gimg/www.for...2d0a7dc37a.jpg https://cimg9.ibsrv.net/gimg/www.for...70bc901c0e.jpg https://cimg9.ibsrv.net/gimg/www.for...c065d21be6.jpg The other is the battery hold down brace from the radiator support to the front hold down bolt. https://cimg1.ibsrv.net/gimg/www.for...c3c623a97f.jpg https://cimg3.ibsrv.net/gimg/www.for...0c5b7c18e3.jpg |
Looking for the older style interior door handles from 1976-1986.
I believe you will find that the 76-79 handles are different from the 1980-86 style. 1987-1996/7 are the same design as the 1980-86, just plastic instead of metal.
I really need an alternator bracket for a 1995 F150 4.9. The bracket also holds the smog pump I believe. I can't find one anywhere! :(
Looking for Frame Member
I'm looking for the frame member that supports the tail end of the Mazda m5r2 transmission in my 1990 F150 short bed 2-door. I'll post a part number in a little bit. I live between Fredericksburg and Newport News VA. Also, if anybody knows where I can find a full frame that would be excellent. Thanks
Part number (as stamped on the member) E8TA-1A 4 9/5 0/5 8 4X2 M5OR |
Hey guys, I still need help from one of you. I need everything to add a manual shifting lever to my BW 1356 transfer case. The linkage, the lever, the cover plate... Can someone get these from a junkyard for me?.
Wanted lower hinges 1995 F350 crew cab. Finger spring intact.
Also hinge cover for folding center front seat. cbun177769@aol.com |
Looking for the console for the center 40/20/40 seat. 95 F350 in NM. Will pay shipping.
Looking for old -style (the kind that mount to the frame) step bars for a '96 single cab gasser. PM me with what you've got & how much you want for it.
NEW MEMBER NEEDS HELP
Hello- I am looking for help finding a engine wiring harness for a 1988 F350 460. Any help would be awesome.
Thank you |
1 Attachment(s)
Does anyone need the stock exhaust heat sheilds for the 460? I have muffler and tail pipes. Figured I'd ask before the system heads to scrap.
Looking for a couple things...
Steering column shroud, both pieces, for bricknose manual with tilt Steering wheel lock actuator...not the ignition actuator, but the piece with the wheel lock Both for my 1989 F250 |
You got pictures?
Originally Posted by jplinville
(Post 16648886)
Have a
95amp 3g alternator(f150) Good ac compressor (f150) v8 Left and right accesory brackets from a explorer v8 (97) Front and rear fuel tanks Injector rail(no injectors) Coil Springs with spacer(will need stocks back) For free to a good home hou tx 77017 |
I have several free things up for grabs that can be seen in my craigslist ad. One is a rear super cab seat in medium mocha that is in nice shape. Also there is a solid glass rear window, and some interior stuff like kick panels and glove box. Please try to reply to the ad my email, since I may miss it here.
https://austin.craigslist.org/pts/5830835035.html https://cimg3.ibsrv.net/gimg/www.for...af15fe0dcc.jpg https://cimg4.ibsrv.net/gimg/www.for...f91017d510.jpg https://cimg7.ibsrv.net/gimg/www.for...7eb03aff9d.jpg |
