What headers for a 351
I have a 56 with a 351 cleveland about to go back in. I was wondering if anyone is running headers other than sanderson? I'm having a hard time finding all the measurements to determine if they will fit in there without issues.
nope - good ol' cast iron on mine.
I want to change them out because all the non-car people I show off to say - "it's all rusty" - drives me crazy - shiny crazy custom made up truck & all they see is the darn cast iron header |
Originally Posted by ohbrian
(Post 13939901)
351c headers
I used 71 mustang mach 1 headers on my 54 f100. they fit fairly tight to the block but were not hard to install. I have transdapt motor mounts and had to grind 1/8 " off them to clear the bottom tubes. I also had to cut a 1/4" notch in the passenger side header exhaust extension flange to clear the transmission oil pan.they are also close to the frame mount brake master cylinder and power brake unit. I used hedman s-bend style universal exhaust extension - they make it much easier to line up your pipes. I would recommend using header wrap on at least the lower pipes to keep heat off the brake unit, the starter, and transmission pan.
dale |
Originally Posted by bra$$monkey
(Post 13949320)
Originally Posted by dale waddle
(Post 13953303)
dale |
I have a 1986 351w in mine, and was not successful on headers, I'm using the Toyota PS kit and on the drivers side, not much room with that gear box.
Thanks guys!
I installed Sanderson's huggers on my 351w and it was really tight with the Toyota box. I have the engine dead center in the frame and there's not much clearance on either side but they do work.http://i822.photobucket.com/albums/z...th_Aug2013.jpg
I run dougs shorties on mine.
http://i205.photobucket.com/albums/b...ps1f3388ff.jpg http://i205.photobucket.com/albums/b...ps70ee7f72.jpg |
Originally Posted by 52 Merc
(Post 13953452)
Before you toss out the iron mani's, try coating them with this. Brush it on and let it bake in. Works good, looks good.
Eastwood Silver High Temperature Exhaust Coating Paint Kit : Amazon.com : Automotive |
Also running Sandersons. I had them coated with Chromex High temp.
https://www.ford-trucks.com/forums/p...ctureid=147199 _________________________________________________ 48 Ford F1 - Darkside 46 Ford Tudor - Street Rod "If it don't go, chrome it" :-jammin |
