2010 F250 and Ford ESP advice
I bought my F250 truck new in 2010 so the 3yr/36000 mile warranty is now up. I only put about 5,000 miles on my truck each year but I want to get a Ford ESP just to be safe. I’m not sure on which one to get. I see a Ford PremiumCare policy but also see a Diesel EngineCARE policy as well. The diesel policy looks like it just covers the engine while the premium policy covers a lot more items. They are both priced similar.. Should I pick one over the other? Or do I need both? I don’t want to buy the PremiumCare policy, only find out most of my engine is not covered. Suggestions?
Thanks |
If it were not for my esp premium care warranty it would have cost me $2,800 just for 2 radiators on my 6.4 I also had a alternator and right front hub bearings covered.
look int aftermarket warranties as they often are cheaper and cover more. plus most of htem cover work to be done by your choice of shops. not just ford shops. I have an ESP now on my 450 and they are not covering the Turbo supply tubes because they say its not a coverd componet. the cost is 2200 to have a 100 part replaced.
This is where I got mine. Ford Extended Warranty | Genuine Ford ESP | Discounted Pricing
Use the search function. There are several threads about this. I highly recommend it! They were cheaper than anywhere else. |
Originally Posted by ljutic ss
(Post 13930586)
if you could get a warranty that will replace parts with aftermarket you could try the fully welded aluminum radiators which should last. |
[quote=Mystic_Cobra;13933600]This is where I got mine. Ford Extended Warranty | Genuine Ford ESP | Discounted Pricing
Use the search function. There are several threads about this. I highly recommend it! They were cheaper than anywhere else.[/quote I just added the info for a 6/75,000 premium care $50 deductable at this link and it is a good price, but I just bought my ESP 2 months ago from Flood ford for $200 less. This is for a new 13 F 150 The dealer I bought the truck from wanted $2,100 and directly from Ford online was $1,800 flood Ford in Ri. charged me $950 i |
