Ford Truck Enthusiasts Forums
-   6.2L V8 (http://www.ford-trucks.com/forums/forum206/)
-   -   Throttle body spacer (http://www.ford-trucks.com/forums/1288417-throttle-body-spacer.html)
JAE88 01-01-2014 07:38 PM
Has anyone tried a throttle body spacer on a SD with the 6.2? If so, did it help any?
jeepnford 01-01-2014 08:12 PM
Most of that stuff helps separate you from your money. I put an intake spacer on a 5.0 FI engine once to clear some fancy valve covers. It made big claims about all the extra power I would have. I couldn't tell any difference.
JAE88 01-01-2014 08:44 PM
I figured that. I had one on my old 5.4 and made 0 difference, but just thought i would ask and check to see if maybe the 6.2 would be different.
BlueOvalJunkie11 01-08-2014 07:23 PM
i think the best bet for power on these engines is a tuner and exhaust
JAE88 01-08-2014 07:28 PM
I have a 5** tuner on the way. Now i just need to figure out what i will do with the exhaust.
BlueOvalJunkie11 01-08-2014 07:32 PM
what cab configuration you got?
JAE88 01-08-2014 07:53 PM
It's a 4 door
Jamie Mendell 01-25-2014 06:12 PM
I did five star 93 performance tune made a big difference on my 6.2 limited also have k&n cold air . This truck rips now
Zecca93 02-12-2014 11:08 PM
i did a throttle body spacer with an airaid cold air intake for my 6.2 SD..installed em both at the same time and noticed a difference but then you just get used to it so in the long run dosent really matter.. throttle seemed more responsive tho with a little more torque
IKEA52 06-12-2014 10:56 PM
Quote:
Hey Zecca93,
What kind of throttle body spacer did you use with your Airaid CAI?
djm1204 06-21-2014 03:04 AM
will exhaust make much difference ? DO I need a tuner to get that difference ?
Thanks in advance for responses
Dan
