PTO Tribulations on a T98
3 Attachment(s)
:-roll
Albatross' T98 has a PTO to drive the lift cylinder's pump. It is a Chelsea six bolt, with a casting number of 450A and all that I can make out of a model number appears to be, or at least end with, "4CFW." It has some issues. Attachment 87504 This is not an easy modification to reverse. The farmer must have wanted to be sure that this never came loose again. Ever. I want to change from the cooty-Bob lever setup hacked into the transmission floor pan and move to a cable system. Attempts to get this nut off may prove to be the undoing of the shaft itself. If the picture is difficult to see, the nut is welded to both the shaft and the lever. Attachment 87505 This seal cover was struck in a couple of places. Evidently it was a deliberate attempt to swell the seal and reduce the hemorrhage of gear oil. It showed to be a vain attempt by the time that I got the truck. Attachment 87506 The seal is for a 1" shaft and has a 1.5" OD and 3/8" thickness. Does anyone know where I may find this seal? And what about that shaft, does anyone have a suggestion for salvaging it intact? Or, perhaps, does anybody have a similar PTO in better condition that they'd be willing to part with? :-huh Inquiring minds want to know! |
There has to be many of these old PTO boxes laying around with unscathed parts. There were brands other than Chelsea and functionality was the same. Sorry, but I sold the one off Blue. So far as the seal, pull it out and get the numbers. Any good bearing, seal shop should be able to come up with a replacement. I really can't see it well enough to tell what you're up against on the lever.
Don't always blame the farmer. |
3 Attachment(s)
There should be P/N's on the seal, that will allow a shop to do an interchange search. Here are the closest ones I saw.
1 Attachment(s)
Attachment 87515
Here is a different view. I'm mostly concerned about how to properly fix this. Thank you for the fast responses on the seal. I am going to have to pull it anyway, I was just hesitant to do so until I had a replacement in hand. :-X21 It is fully possible that the original lift bed/grain box installer did this hack job, but, the truck has only been owned by two farmers in its prior life. According one of the town folk, the last guy who owned it never really drove it at all. He apparently bondo'd the body liberally, slathered paint onto EVERYTHING(!) with a brush, and then let it sit for ten years. Then I got it. |
Some careful grinding and you may get lucky .
Yes grinding off the welds carefully should get the nut off.
I have done this several times on heavy equipment. Go slow and use a new grinding wheel on a 4 inch angle grinder. Once the weld is ground to where ya can see the crack between the two parts and the circle of the shaft on top it may unscrew. Buy a nut splitter at this point may be in order. |
Well, grinding down through the face of the nut/shaft mess has exposed a slag-filled porous tunnel that includes a major portion of the shaft. In other words, the shaft has been burned with a torch and what's left of it is very solidly fused to the nut. It's starting to look like I need another PTO or perhaps at least a donor unit. If anybody has a lead on one, I'm definitely looking. I need most any six bolt PTO that will fit a T98 or T18 and point to the rear when mounted on the right (passenger) side. I'd consider others (such as a dual-shaft).
Thanks, Jeremy BTW: It would probably also fit a spur-gear crash box and/or a T19.. Anyway, I'm a-lookin'. |
Could we see a pic of the shaft and nut since ya ground it down?
Don't be proud, just re-weld it after you do whatever you are doing to it. This is known as "cootie-bob'ing" and face it, who's going to see it?! }>
Good point Ross. Just hope the new seal survives.
Aftermath
1 Attachment(s)
I cut, ground, nut split, ground some more, and I managed to salvage 1/2" of useable threads on the shaft because they had put a 3/4" split washer behind the lever. This worked out to my advantage. :-X03
Here is what's left: Attachment 87546 I chased the 1/2-20 threads and there is just enough to use. The home made lever never had splines, there was a small bushing smashed onto the splines. Well, now there's another seal to figure out because this is oozing too. Then I'll figure out how to connect it to a cable system. It looks like another one may live to work yet another day. :-jammin My T98 is together and the PTO is all that's left for it to be ready to roll. I can soon get to finishing the details of the 292 such as painting the bell housing, front mounts, engine, and get it running. :-blah Details on the T98 rebuild should be posted in a week or so. :-drink:-drink |
Looking good. Glad ya got it.
If you still have your trans open, could you post a picture of how 4th gear mates to the input shaft? I never thought about it, but it must be like a synchro hub minus the synchro? Or do they actually get 4th (direct) by having 5 gears on the cluster?
Good job !I can see that working again .
3 Attachment(s)
Originally Posted by ALBUQ F-1
(Post 13892642)
Overview: Attachment 87561 3rd/High Synchro Sleeve: Attachment 87562 3rd/High Hub and fixed gear: Attachment 87564 BTW: the PTO seal is marked "206 CR." EDIT: hub is splined to output shaft. :o |
