Yellow Liquid found on driveway
Good Morning,
over the past few days I have noticed that under where ever I have parked there is a small amount of yellow liquid on the ground, I have checked and my antifreeze is between the the Cold start min and max, I drive a 2013 F-150 5L Any Ideas what it could be? thanks RH |
Rub it between you fingers and smell it. Antifreeze feels slippery and smells sweet. Water is odorless. If it smells like pee then you need to drink less booze.
Be careful with antifreeze. If an animal even just tastes it then they will likely die. And dogs like to taste it because of the way it smells. |
I have had the pleasure of being the designated driver the last few days so it is not the later, and I do not believe it to be Antifreeze because it just melted the snow on the driveway but did not dissolve it
What color is your windshield fluid? And where exactly does the liquid pool under the vehicle?
I would blame the dog . Yours , or the neighbors ...
I use rain-x washer fluid that is yellow like anti-freeze.
I think the coolant on all the newer trucks is pink.
Where at under the truck does it pool up?
