Ford Truck Enthusiasts Forums
-   1994.5 - 1997 7.3L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum170/)
-   -   advise please! (https://www.ford-trucks.com/forums/1281095-advise-please.html)
oldbird1965 11-23-2013 07:14 PM
advise please!
http://i1282.photobucket.com/albums/...psc8f23363.jpg
As you can see, my new bellow is right up against the trans, again. I don't know what to do about it. I don't want another hole rubbed in it. Maybe I just got a deformed set of up pipes. I put a pry bar up there and just after putting a little pressure on it, I stopped. Didn't want to ruin my new bellow. Then I shifted my head back and towards the frame, I caught a little light thru there. I thought to myself, that's paper thin so what the heck, I went and got a piece of paper. I could push the paper thru and then doubled it up and couldn't push it thru. Its that close. What should I do, pry on it some, leave it alone, pull it and try to bend a little, drill out the mounting plate and egg shape the holes so I can move it over a hair. Instead of bolts I could use bolts with a nut from the bottom. There is room on the passenger side to move every thing over a hair. I hate to drill out the threaded holes but a paper thin clearance isn't enough, is it???? :-X15 :-X16 x( :confused:
texastoolman 11-23-2013 07:19 PM
Thought about grinding the housing a little?
OldWoodsDiesel 11-23-2013 07:20 PM
Can you take the up pipe off and just grind some of the aluminum trans case back in that spot? I wouldn't see that causing any harm and precision would not be necessary.
oldbird1965 11-23-2013 07:21 PM
For your first post Tex, that's a good idea. Stick around and welcome!!
Thanks JB.
Edit: I meant JP, LOL
ReBilld 11-23-2013 07:33 PM
Have you bolted the up pipe to the manifold yet?
ReBilld 11-23-2013 07:40 PM
I don't like where that bellow is on Jake's pipes. It should be down lower. There is a piece that sticks out on the back of the head right there. The factory up pipes have an indention in them so they won't hit it. I put my bellows lower.
https://www.ford-trucks.com/forums/p...ctureid=140068
oldbird1965 11-23-2013 08:02 PM
Yes, everything was tight.
I'm wondering about Jake, period!! I like your idea but for myself I'll either grind that down or ?? I'm having problems and Gabe and Darin aren't makes me believe I got a retarded set of pipes, LOL. How much clearance do you think I need Bill?
ReBilld 11-23-2013 08:10 PM
Just enough so it doesn't touch. Loosen the bolts where the up pipe is bolted to the manifold. Tighten the top one first and see if it will draw the pipe enough to bring the bellow away from the trans, then tighten the bottom one up. This may not work, but worth a try before you pull it all out again. If it doesn't, then grinding a little on the trans case may be your only option.
fordpride 11-23-2013 08:12 PM
I'd grind it. I'd grind about a 1/8-1/4" out.
oldbird1965 11-23-2013 08:37 PM
That's what I did Bill, I started the manifold bolts, left them loose, then tightened the top mounting bolts. Unless you mean there is a top and bottom bolt on the manifold?
Sounds like a plan Mike, I hope I can get my grinder in there, LOL
ReBilld 11-23-2013 08:47 PM
Yeah, that's what I meant. Tighten the top one and it will kinda roll the up pipe over to that side on the rounded flange of the manifold. You don't wanna over do it and put the pipe in a bind, just enough to see if it will pull it away from the trans. Then tighten the bottom on down pretty snug. Like I said, it may not work, but worth a try before you pull the whole deal out again.
oldbird1965 11-23-2013 09:24 PM
OK, that's a good idea, I'll try that. Thanks Bill
ReBilld 11-23-2013 09:31 PM
Either way, I hope you can get it right without too much trouble.
oldbird1965 11-23-2013 10:42 PM
Yeah, two great suggestions, I wish I could work on it tomorrow. Doing an early Thanksgiving with some family. Sure glad I didn't put the turbo back in before I looked, LOL
fordman67 11-23-2013 11:08 PM
im late to the party...i would either grind it,throw it through irates front window or send it to bill to be made the way irate should have in the beginning....lol:-arrgh
