AWD not working. Direction needed.
Okay the problem is my AWD in my 98 Ford Expedition doesn't work. When shifted into AWD in starts flashing. The 4HI does work but it will not shift on the fly. You have to come to a complete stop to get 4H to work. 4L works like it's supposed to. I have read the post on this problem. Shift motor is working, took it off to confirm. From actuator is also working. I have read that the sensors in the transfercase could be the problem. My transfercase has 2 of them. Are they both the same sensor just checking different things? Do I have to replace 1 or both to fix my problem? Have also heard that the speed sensor on the rear axle could be the culprit.
The part number for the sensor on the transfercase is 1L2Z-7F293-BA. About $50. Does anybody have any further info on what these sensors do and how to fix? It's my wife's truck, and would really like the AWD and the 4wd to work the way it's supposed to. |
I agree that it's probably one of the transfer case sensors. Judging from the fact that you cannot shift on the fly but can when stopped, I suspect the front sensor, or it's circuitry is the problem. If the rear sensor was the problem, then the speedometer wouldn't be working.
Okay. Where is the rear sensor mounted. To the left of the transfer case motor or to the right? I can't quite remember how they are mounted. Are both sensors the same part number?
I appreciate the post. 85 views and 1 post. I was getting nervous.
2 Attachment(s)
Originally Posted by Firefighter 1406
(Post 13772867)
Thanks. That's awesome. I appreciate your help. Do you know if they are the same part numbers?
(Post 13773298)
I appreciate it. Have to get this done.
Old thread but I found it. Alright got the sensors fixed. AWD stays shifted in now and doesn't flash anymore. Still will not shift on the fly into AWD or 4H. I know my actuator motor is working. And last time I checked my front axle actuator was shifting also. I am at a loss.
(Post 14934233)
From 2H it will not shift into 4H or 4L.
(Post 14934791)
Originally Posted by alloro
(Post 14934868)
You have to be stopped and in neutral to shift in or out of low. But 2H to 4H or A4WD should happen at any speed under 65 MPH. Can you shift between 2H, 4H, and A4WD when stopped?
relpy
replace both be safe. If one is bad the other is soon to follow.
I did replace both the sensors in the transfer case.
