FABRICATION!! We want to see what you've built.
The recent thread asking if you kit or fabricate brought to mind a thread that I started over a year ago regarding fabricated or modified parts. I find it really time consuming trying to search for custom work, wading through galleries or using the search feature. I'd like to propose a running thread of your fabrication projects whether made totally from scratch or a modified part.
I belong to several forums where there are threads that have run for quite a long time regarding things like home brewed tools, storage ideas, welding projects, etc..... They are quite interesting to read and even if the way they're presented doesn't work for you, it may give you food for thought on how you might use it. I'm constantly going back to those threads to see what has been added This may be duplicated information from your build thread and may require a little more effort to post here, but it will be located in one place to see work that others have done and may be what you're looking for. |
1956 ford truck frame with a camaro subframe, air bag system installed and many other mods.
53-55 Instrument panel
I'm currently working on my butchered instrument panel. When I got my truck it had the original instrument panel cut up with a several different kinds of gauges mounted in an aluminum panel that was covered in fake wood grain.
I performed a little more surgery on the panel and opened it up where I could mount a real wood panel. I also sanded the rust and paint off the ring that surrounds the instrumets and buffed the ring. I plan to shoot this with adhesion promoter and clear coat. Lot cheaper than chrome and looks better than the paint and rust. http://i261.photobucket.com/albums/i...instrument.jpg My wife ordered some new Autometer gauges and I searched through my scrap pile of wood in search of just the right piece. http://i261.photobucket.com/albums/i...nstrument1.jpg I cut out 3 different panels.....one each in cherry, walnut, and red oak. http://i261.photobucket.com/albums/i...ravan/Dash.jpg The cherry got my wife's vote and it does have some interesting patterns. I cut all the holes for gauges, signal lights and high beam. I'm currently working on the finish. http://i261.photobucket.com/albums/i...avan/Dash1.jpg Updated 10-29-13 Several coats of clear automotive finish. http://i261.photobucket.com/albums/i...avan/dash7.jpg Install gauges. http://i261.photobucket.com/albums/i...avan/dash6.jpg http://i261.photobucket.com/albums/i...avan/dash8.jpg http://i261.photobucket.com/albums/i...avan/dash4.jpg |
<a href="http://s125.photobucket.com/user/calorchard/media/Mikes%20Jeep/photo4_zpse27072f6.jpg.html" target="_blank"><img src="http://i125.photobucket.com/albums/p74/calorchard/Mikes%20Jeep/photo4_zpse27072f6.jpg" border="0" alt=" photo photo4_zpse27072f6.jpg"/></a>
Drew, your post is very timely and I like your setup. I've been working toward something similar but using other materials beside wood. As I'm using redwood for my flatbed I kind of like the idea of having them match.
:-drink |
Originally Posted by Rocketman55
(Post 13660068)
:-drink I think the matching wood would look great on your truck. |
ha ha, mine is a budget build as well. It keeps taking more of my budget.
Home brewed running boards
A lot of you guys have seen this before so bear with me.....I'm checking to see how easy it is to copy paste old posts.
I had originally intended to use the stock looking ribbed running boards on my truck, but decided that the look didn't fit the truck. I decided to take a shot at making my own boards. Using masonite and wood, I mocked up the shape I wanted. http://i261.photobucket.com/albums/i...May2010052.jpg Transferred the shape of the pattern to my metal blanks. http://i261.photobucket.com/albums/i...n/P1010236.jpg Lots of cutting, welding and grinding. http://i261.photobucket.com/albums/i...n/P1010243.jpg http://i261.photobucket.com/albums/i...n/P1010247.jpg http://i261.photobucket.com/albums/i...n/P1010255.jpg http://i261.photobucket.com/albums/i...oardfab005.jpg http://i261.photobucket.com/albums/i...n/P1010356.jpg I had decided to exit the exhaust through the running board, so I fabbed a ring that would be used to form the character of the exhaust opening. http://i261.photobucket.com/albums/i...n/P1010330.jpg http://i261.photobucket.com/albums/i...n/P1010325.jpg http://i261.photobucket.com/albums/i...n/P1010326.jpg I had to extend the bottom edge of the board to make the exit point look correct. If I had this to do over I would have incorporated the extra material in my board blanks to avoid the extra welding. http://i261.photobucket.com/albums/i...n/P1010340.jpg http://i261.photobucket.com/albums/i...n/P1010338.jpg Lots of smoothing, priming, and blocking. http://i261.photobucket.com/albums/i...n/P1010355.jpg http://i261.photobucket.com/albums/i...n/P1010365.jpg http://i261.photobucket.com/albums/i...n/P1010364.jpg http://i261.photobucket.com/albums/i...n/P1010997.jpg http://i261.photobucket.com/albums/i...n/P1011106.jpg It was a bunch of work, but cheap to build and not like everybody else. In hindsight, I would have tapered the running boards from where the exhaust exits all the way to the front where the board meets the front fender. |
I dont really know if this qualifies as fabrication but what the heck??
DinnerHill SpeedShop: Construction of KPH scale DinnerHill SpeedShop: Speedometer |
1 Attachment(s)
Heres one . I needed a new battery box
2 Attachment(s)
I have to fab stuff almost for vehicles almost daily it seems.
One of the more fun projects was building a sheet metal break. I made it from steel I had laying around, it will bend 18 ga 4 foot wide. It could use some counterweights though if I ever get around to it... |
I needed to make mounts for my bucket seats. I wanted to be able to remove the seats quickly so that I could work under the dash.
https://lh3.googleusercontent.com/-i...-p/001-016.JPG https://lh6.googleusercontent.com/-f...-p/003-019.JPG https://lh4.googleusercontent.com/-R...-p/001-017.JPG |
2 Attachment(s)
Complete core support setup for my 56 (and a Chevy bumper)...
