Scangauge Readings?
I have a Scangauge II on my 02' F350 7.3 and it will read all the gauges that my 05' Excurssion V10 would display except for engine coolant temp. Is this due to the ODBII difference with these year diesels I've heard about.
And can anyone explain that a little more to me. I've heard that if I take this truck to Autozone for a free check engine light reading they might not be able to read them?? |
02+ trucks are OBDII compliant. 99-01 will still read all of the gauges, thats different. If you took your truck to Autozone they would be able to pull codes since its OBDII compliant. 99-01 they can pull some codes.
I have a cheap $50 scanner I use. It works great. |
So I guess I need to figure out why my scangauge won't read my engine temp, hmmm?
Originally Posted by glockholiday
(Post 13633133)
Mine works great for water temp her is the Xcode for water temp:
Coolant Temp: TXD: C410F1221139 RXF: 046205110639 RXD Engine: 3008 MTH: 00010002007F NAM: ect The value displayed by this XGauge is only valid after the coolant temperature gets above 127* F. Before the engine is warmed up the displayed value will go up to 255 this about double actual then start over at 127. This is becasue this PID is scaled for two different ranges. It works good on my 2000 7.3 and seems to be accurate. This has been a long sought after XGauge for the 7.3 crowd for quite some time. |
(Post 13633133)
Manual transmission models should work fine though.... |
