Ford Truck Enthusiasts Forums
-   1997 - 2003 F150 (https://www.ford-trucks.com/forums/forum25/)
-   -   98 F150 4.6 4x4 no power (https://www.ford-trucks.com/forums/1270387-98-f150-4-6-4x4-no-power.html)
redrock233 09-29-2013 04:55 PM
My 4x4 will not engage there is no power at the on the fly shift switch. So I was wondering where it gets its power from have checked all fuses and vacuum lines wires and all any and all info will be greatfully accepted thank you all.
I have read through most if not all post that I can find and nothing
Bluegrass 7 09-29-2013 05:53 PM
Well it's not that simple.
The switch signals a module called a GEM.
The Gem operates a transfer case motor that moves a shift control shaft and electrical connections to the first position.
This operates a vacuum solenoid on the fire wall to apply vacuum to the front axle actuator.
When these actions are complete the Gem lights the dash 4H lamp.
If the case motor does not operate it is a Fuse, the motor, or the GEM module.
The dash switch seldom ever goes faulty.
Good luck.
redrock233 09-29-2013 06:19 PM
Good luck.
Ok so it just might me the GEM everything else has power or moves freely.
