WTB i6 300
Looking for a good running i6 300 my 240 just took a dump on me major blow bye .
I have one that is known to be good. $250 complete or $200 for the long block.
Where are you located any specific details about the motor like year miles compression checks? What does it mean known to be good ?
The motor only has 152k miles on it. The head gasket was replaced by me in september of '11. I had the head cleaned and pressure tested, and while it was off, I looked at the cylinders, and they barely looked worn at all, i could still see the crosshatching on the cyl. walls, and there were no vertical wear marks. I put 24k miles on the truck, with regular LOF's, and it didn't burn any oil, and didn't smoke at all.
any idea what it would cost to ship to San Diego California?
I don't have any connections to get it to the west coast. If you were on this side of the mississippi, I could have delivered it, but i didn't know where you were. Sorry.
Its cool thanks ill keep looking. Also looking for a AOD in working condition
Anyone else still looking for 4.9 and AOD combo SOCAL
I have a "project" 300. Not sure if it would be what you are looking for, but here it is.
No idea of the miles on the short block, but the head is fresh from the machine shop. It was a decent runner but lost a timing gear. Gears have been replaced and a lot of work done to the head. The short block is together with the (fresh) head off. Also have a set of EFI exhaust manifolds to go with. Drop me a PM if interested. I am in the Portland, Oregon area. Roger Carter |
