fuel pressure gauge
where can I get the fitting for testing fuel pressure
A hydraulic shop. The fitting is 1/8 NPT x M12 x 1.5
I got mine from Diesel Manor, along with the fuel pressure gauge.
By the Way........ what's the correct fuel pressure I should be seeing with the blue spring upgrade ? My gauge sits very steady on 65psi............. is this correct ? TIA............. |
Originally Posted by ihandy
(Post 13522412)
Originally Posted by GSlahor
(Post 13523218)
ihandy....check out ITP (think they're merged with MKM Customs/Sinister)...they have a nice line with a schrader valve.
GSlahor....I read a steady 65psi...sometime it sits at 67. |
I took the old plug left over from the blue spring upgrade drilled out the center then brazed on an air fitting so I could attach a hose with a guage to check the pressure worked great
