Fuel treatments? Whats the best for Diesel
I have a 2006 Ford 6.0 L that seems to only run well when I use a fuel treatment. truck has about 145,000 miles on it and when I run straight right out of the pump diesel It runs sluggish and my mileage drops a bit.
Also Has anyone heard of or use a product called REV-X? Its not available where I live but I have heard it works great on the ford 6.0 Any feedback would be great! Lots of fuel treatments out there but some seem like nothing more than a waste of money. I have been using Diesel Kleen and Stynadyne with good luck. but looking for something that will help the motor better if there is anything? |
Where do you live, if you don't mind me asking.
A lot of guys run the Diesel Kleen. I run it in every tank. I have never heard of performance issues without it though. You may want to keep an eye on your FICM. The Rev-X goes into the oil and is supposed to help keep the injector from sticking. I can't say it works or does not work but, never heard of it hurting anything. . |
I live in Oregon, so far only one guy who works at a Napa Store said he has heard of REV-X, best I can find its not really used here? Seems to be a Midwest item.
Reason I ask about the REV-X Is my injectors seem really noisy. I changed the oil to synthetic but now they actually seem louder. I heard the REV-X is suppose to really help the oil and quiet the injectors? Also the FICM Is something I'm a little worried about, every so often I have to push a connector back in to get truck to start after a long hot drive. Actually left me and my son stranded today high up in the woods, no cell phone coverage and no people around we got a bit nervous. Luckily the Ford gods heard us and we got started and headed for home! |
i use archoil 9100 for oil and 6200 for fuel. much cheaper than rev-x
Originally Posted by d450heavy
(Post 13496490)
I run Motorcraft's Diesel Cetane Boost and works well for me.
Originally Posted by daddykitty
(Post 13496657)
Run High sulfur and you won't need any additive. :D
(Post 13496347)
You guys have any thoughts on marine 2 stroke oil in your fuel? Have a friend that swears but it he runs it in every tank of his dmax.
(Post 13496657)
Thanks for all the great advice. Also good to Hear someone has used REV-X with positive benefits.
I have at times put both Diesel Kleen and Stynadyne in together, did give me much better throttle response and a tiny bit better MPG's, I have a friend who swears by the combo of Marvels mystery oil and Stynadyne together. He pushing 250k on his 7.3 and still going strong. I'm going to order some REV-X tonight and see if it helps my noisy injectors and hard starts hot problem! I let you all know how it works. |
What weight of engine oil are you running? If you are running 15W-40 try switching to a full synthetic 5W-40, your injectors will thank you. :-X22
I am also a motorcraft cetane boost user. |
(Post 13498441)
I am running the Rotella 10-30 diesel blend synthetic now, changed the oil about a month ago and now get about 3 miles per gallon more. I drive a lot about 1000 to 1500 miles a week so I am thinking about changing the oil again this weekend and this time using Full Synthetic 5-30 and see if the injectors and hot starts go away. Also will be adding the REV-X to see if it helps the injectors.
I also have heard a few guys using Marine 2 stroke in their trucks. Seems risky but I am new to the whole world of fuel additive thing. In Oregon we cant get anything but low sulfur Diesel. Not sure of the Cetene rating. We unfortunately live in a state where 90% the people live in one small area and they in turn make the laws and rules for the entire state. And they prefer to ride their bikes to work or drive their smart car. Wear I live everybody drives a truck and most people don't even go visit the towns were the laws are written, so if really doesn't help us out at all. Any advice on the best Oil to run in the 6.0L manufacture and Weight going into winter? Also how often do you all add the fuel additives, Every fill up? |
