Ford Truck Enthusiasts Forums
-   Oregon Chapter (https://www.ford-trucks.com/forums/forum190/)
-   -   84 ford f-150 (https://www.ford-trucks.com/forums/1264921-84-ford-f-150-a.html)
waltharper 08-31-2013 03:16 PM
84 ford f-150
looking at a 84 ford f-150, 300 cuin and auto to buy
they say it has 94K on the clock......
What should i watch for?
Tempted to put the 300 and auto in my 62 f-100
fabmandelux 08-31-2013 05:12 PM
Afternoon Walt. 94K on a 300 six is not much depending on the maintenance he's done. Not much different checking things. Check the radiator fluid, check the oil and trans oil for burnt smell, color, etc.
The 300 would be a great engine/trans combo for your 62! Pull the smog crap off. Install a Offie 4 bbl manifold, 350 Holly, and a set of headers, amd BINGO! Plenty of pull power and 20+mpg!
It's what I've got in my 67 shortbed......
waltharper 08-31-2013 06:43 PM
What gear ratio do you have in your rear end?
Should the 84 have a computer and electonic ignition?
fabmandelux 08-31-2013 07:04 PM
I have no idea what the ratio is Walt.............But I can look when I go to the shop tomorrow.
An 84 will NOT have a computer, but will have Duraspark ign. It may have a "feedback" carb on it but it can be thrown in the junk and replaced with a different one.
Old93junk 09-02-2013 07:30 PM
Probably no feedback computer carb on a 300-6 1bbl, that went mostly to the 302s with the 2bbl 2150A feedback carb.
waltharper 09-09-2013 05:02 PM
I waited to long, it is gone but I am looking for 80 oit 85 as a donor vehicle.
If I change out the steering colum from a 65,do you think I could use the steering box from a 81-85 f-150 or get a toyota box?
