4x4 99 ranger front wheel bearings, how hard?
They are a squeaking and drivin me crazy. how hard are they to do, do they need a press or can they be done at home?
Here's link on replacing them. If you have a NAPA with a machine shop you could remove the rotors get them checked to see if salvageable and need turned and buy new bearings/seals and have them reinstall and pack them with grease so all you would need to do is reinstall.
| Repair Guides | 4-wheel Drive Front Suspension | Front Wheel Bearings | AutoZone.com |
I may be wrong about this, but i thought my disks slide right off once the wheel is off?
From what I read it appears they do so you don't need to deal with the rotors. Am used to the 2wd setup and no such luck with them.
Are you sure it's the wheel bearings that are squeaking?
The '98-'00 4x4 Ranger front hub bearings are not serviceable. You will need to replace the hub/bearing assembly as a whole. Check out: TRS Magazine - 98-00 Ranger Hub/Bearing Assembly Replacement IIRC you have also been having issues with the front hubs failing to engage. So you might also consider replacing the original PVH hubs with the AVM manual lockers while you are at it. |
Originally Posted by Rockledge
(Post 13489820)
I believe the transfer case motor is bad also the hoses in the hubs are rotted and the lines corroded |
I actually have the front drive shaft out right now! But yeah, I dont think its engaging. Been meaning to get around to fixing it, but since I have never really had the need its been on the way way way back burner.
