1999-2012 Ford F250 Truck Super Duty Power Window Regulator with Motor Front Driver Side
VISIT US HERE FOR GREAT PRICES 1999-2012 Ford F250 Truck Super Duty Power Window Regulator with Motor Front Driver Side
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES!!! http://static.1aautoimages.com/partp...2/middle_2.JPG This replacement power window regulator with motor is just what you need to get your vehicle in good shape again! Specifications: LH (Driver Side) FRONT Replaces dealer part numbers: 8C3Z-2523201-C, 8C3Z2523201C, F81Z-2523201-BA, F81Z2523201BA, XC3Z-2523201-BB, XC3Z2523201BB, 1C3Z-2523201-BA, 1C3Z2523201BA, 6C3Z-2523209-AA, 6C3Z2523209AA, F81Z-15233V95-BARM, F81Z15233V95BARM, F81Z-15233V95-AARM, F81Z15233V95AARM Power operation Direct replacement Includes Power Window Motor already assembled to regulator Built to strict quality control standards Assembly works for models with or without Autodown Feature Note: For 1999 model trucks, there were two options for window motor plugs: vertical or horizontal pin. The plug on this motor has horizontal pins. If your vehical has vertical pins, this assembly will work if you swap the plugs from your original. This power window regulator with motor makes a great replacement and has good cost savings over a dealer unit. Installation This repair is easier than you may think. You'll find our installation videos helpful. In our experience removing and replacing the door panel is the most involved step in the repair. On most vehicles this only requires removing a few screws and push in clips. You'll get a great feeling of accomplishment after you complete this repair knowing you saved money, and you didn't have to give up your car for a day at the repair shop. Your passengers and other drivers will be amazed. Fit guaranteed 1A Auto will refund you with no hassle, if this Window regulator does not fit the application stated. You can use your existing hardware and wiring harnesses. This Regulator will install just as your original does. Save time and money. Quality Be confident this part will work right. Every regulator is tested after assembly to make sure all mechanisms are working correctly. It is important that your new regulator works for a long period of time. The design of this regulator is tested to withstand 10,000 cycles. That is enough to raise and lower your window 3 times per day for 9 years. Nothing is more frustrating than taking your car apart and finding the part you purchased does not fit. You want the part to fit. This design is test fit on an actual door. When you install it, you will have no issues. Value Windows that don't work can be frustrating. They can also hurt your vehicles value. An inoperable window could mean $200-$500 discounted off a dealer trade value or asking price. Some shops and dealers charge more for parts and repairs when they think you don't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly repair bill. Lifetime Warranty This item is backed by a manufacturer's Limited Lifetime Warranty. In the event this item should fail due to manufacturing defects during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. This part replaces: HOLLANDER #: 125-2114L -2118L -2116L -2155L OE #: 8C3Z-2523201-C PARTSLINK #: FO1350149 DORMAN #: 748-212 |
back in stock
back in stock
