Ford Truck Enthusiasts Forums
-   2007 - 2014 Expedition & Navigator (https://www.ford-trucks.com/forums/forum174/)
-   -   2009 Navigator - Factory Keypad Code (https://www.ford-trucks.com/forums/1258972-2009-navigator-factory-keypad-code.html)
jurban91 08-01-2013 06:13 PM
Hi everyone,
I am trying to find the factory keypad code for my 2009 Navigator L.
Been looking around the forum for a few days. I have tried to look into the fuse-box located under the glove compartment area on the front passenger side as this thread stated: https://www.ford-trucks.com/forums/8...ntry-code.html
I found the sticker, which says "FoMoCo". The only 5 digit code I found was the "Date Code". That code didn't work.
Is there any other place where I can look?
Any help would be welcome.
Thanks.
JWC 3 08-01-2013 06:25 PM
They use to be on the keyles entry module . My 04 mounty was that way . It was on the pass side rear behind a trim panel . Not sure on yours though . If you can locate the module it may be on it . Hope that helps .
jurban91 08-01-2013 07:05 PM
Hm, I have no idea where the keyles entry module is situated. Ill try to look around on the internet. Hopefully someone on this forum can point me in the right direction.
alwaysfords41 08-02-2013 01:46 PM
Depending on what you read, some say it was removed from under the dash after 05, then others point to the label you show in the thread you linked to. You may want to give it another try and make sure you are hitting the keys firmly in case one is sticky.
teepee542 08-05-2013 06:51 PM
on my 12 expedition it was on the back of the module that is behind the kick panel on the passenger side. I remove the sill plate trim and the kick panel. I also had to remove the screws holding the module in so that I could pull it back and get the code. A lot of effort but it paid off in the end
