Ford Truck Enthusiasts Forums
-   Cooling, Heating, Ventilation & A/C (https://www.ford-trucks.com/forums/forum61/)
-   -   EATC problems on 96 Explorer Eddie Bauer 5.0L (https://www.ford-trucks.com/forums/1258701-eatc-problems-on-96-explorer-eddie-bauer-5-0l.html)
oldmanXJ 07-31-2013 01:38 PM
My AC isn't working on my 96 Eddie Bauer 5.0L Explorer. Mechanically everything is fine. The problem is that there is no drive coming out of the EATC to activate the clutch on the compressor. Both the high and low switches are fine. I can probe the connector on the output of the EATC and drive the purple wire with 12v and the compressor clicks on and I get cold air. I have run the built in self test and got 888 back so it isn't showing any problem.
I was wondering if a bad cabin temp sensor could cause it to not turn on the AC? I am going to go to the heat setting and crank down the set point to see if the heater will turn off. Does anybody have any experience with this? Is there anything else I should check. I have the real Factory wiring/troubleshoot CD for 96, but it won't load on my Win7 laptop.
I'm an electrical engineer and was wondering if there is an output drive transistor that might be blown. Does anybody have schematics for the EATC internals?
