Brewing temp got away from me
I had preheated the WVO to 145 deg and transferred it to my mix tank. I usually lose a few degrees in the transfer. It was about 137 deg prior to adding KOH/meth so I turned on external heater and added chemicals. I shut off external heat at 140 deg. The temp continued to climb to 149.7 deg at which time it finally peaked only after forcing the temp to stop by placing heavy metal heat sinks in the mix. I was getting nervous. I vaguely remember the flash temp for the methanol to be 148 deg (I may be wrong). This is the first time I could not control the temp. Do you think it was a chemical reaction that caused this? I did add the chemicals faster than usual. The batch came out fine although I probably flashed off quite a bit of methanol. It was over temp for approx 45 min.
Wishing all my "brewing brothers" the best and thank you for your continued support of our forum Tom D |
Howdy Tom! I had it happen once and a small "cloud" of vaporized Methanol "floated" above the mix. Scared the crap out of me, but turned out OK........
Originally Posted by fabmandelux
(Post 13361759)
Great to see you are still keeping an eye on me and keeping me out of trouble I certainly didn't want any kind of fire. That's my worst "F" word nightmare Thanks as usual for the help all these times Tom |
Originally Posted by Tom D
(Post 13359885)
I'm betting that's what happened here ... gotta let the methoxide cool off before adding it to your WVO, or you'll see your temperatures climb. As long as you've got a pressure relief valve on your reactor, though, you should be all right. |
I've almost had the same thing happen, learned to shut off the heat around 120 - 125. Temp usually continues to climb as reaction takes place.
Good to see everyone's still active, thought this site would get busier as Diesel prices went back up. Running $3.85 here. Stay safe! |
