oil filter
Does anyone know if there is a cartridge style over-the-counter oil filter that will work in a 239 flathead?
NAPA # 1006. I have also used #1004 in a pinch. They are good quality WIX filters.
In a super pinch fram C4.........at orileys.
1 Attachment(s)
Originally Posted by obscurity
(Post 13326208)
I think I just need the cartridge element. The engine has most everything else in your illustration. I have thought about adding a spin on conversion but at least in the short term I am looking for a cartridge element I can use without having to mail-order it.
The filter element is as described by Tinman, NAPA stocks them. The filter system does not lend itself to using a spin-on because it only filters 5% or so of the oil pumped by the engine, and gravity drains to the oil pan. There are ways to convert to a modern 95% filtration system with remote spin-on element, but they require complete engine disassembly and modification.
(Post 13334083)
Since oil filters were an option back then, are you asking for the cartridge oil filter element (6731) only, or a complete cartridge oil filter assembly?
Originally Posted by EAK69
(Post 13336213)
Where did the pic come from (book, online, manual, etc)?
Fram C4
WIX 51006 Purolator P34 Napa 1006 Motocraft FL25 |
