Which transmission do I have?
I have a 1995 Ford F-150, 4x4, 5spd, with a 4.9 inline-6. It just rolled over 194,000 today. I changed the oil in it today, and I was inspecting it and I noticed that on my transfer case, down by the drain plug, there is a nice little hairline crack coming from the plug. Whoever the idiot was that changed it last must have used an impact wrench on it! :-X09
Anyway, if this motor ever decides to quit on me, which it probably never will, I am looking at a few different possibilities for an engine swap. First things first, can anybody tell me what transmission I have now? The numbers I found on it are as follows: F1TA GC B805916 The transfer case numbers are as follows: Borg Warner 13-56-065-910(I am assuming this is either a part # or a casting #) On the tag on one of the rear bolts: BO25 1 1356-78 160258 F5TA-HA |
I am sure there are books out there with those numbers, but if you are the original owner, and/or you are sure the tranny has never been swapped, you can get a code off of the sticker on the inside of the door on the driver's side...The stickers should have something like a heading that reads "trans" and a code underneath that...
Give us that code, and it will likely be a quicker ID...:-X10 1987 F150 Reg Cab, 302MFI, AOD, 3.55 Rear, K&N Filter https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4972&.jpg |
I am going to say you have the Mazda Tranny with the inline 6 and it being a F150 I have a 302 and i have the mazda. If it were a F250 it could have had the ZF tranny.
What can you tell me from this?:
Trans: M Axle: 19 Springs: KI Also, what axle do I have and what can you tell me about the springs from this code? Thanks. |
OK you have a Mazda Tranny 3.55 rear end NON limited slip and the spring codes just give me part numbers. I go this info from a Ford Service CD i bought off Ebay for 15bucks. It comes in handy you should look into getting one.
What kind of horsepower and torque limits are we talking for a tranny like this?
I have 275 give or take a few and it does fine. I would say if you go more then like 300+ you might want a ZF but i am not really sure on this.
are you talking hp or ft-lbs?
HP i forgot what i had for tq LOL
I'm not sure about hp yet, but I will probably be running in the 400 ft-lb range.
