Ford Truck Enthusiasts Forums
-   Y-Block V8 (239, 272, 292, 312, 317, 341, 368) (http://www.ford-trucks.com/forums/forum56/)
-   -   Looking for high-end water pump (http://www.ford-trucks.com/forums/1253311-looking-for-high-end-water-pump.html)
bkbauer1955 07-03-2013 08:28 AM
Looking for options on water pump for 1956 ford 312 (in my f350) - looking for high flow, or billet, or aluminum -- any links or ideas /.?
charliemccraney 07-03-2013 04:32 PM
I'm not sure if the aluminum pumps are still available.
Try FORD Y
It will be a pump with car dimensions which will require a matching car pulley.
If it will be used primarily for drag racing or local car shows, you can try Ted Eaton for an electric version.
Eaton Balancing | www.eatonbalancing.com
A stock pump should cool a stock or even modified Y well enough. Do you have a cooling problem or simply want some bling?
chetspencer 08-02-2013 01:39 AM
I just got one from NAPA, working great. Lifetime warranty. Make sure you get the correct shaft size. 3/4" or 5/8".
The Horvaths 08-22-2013 07:07 AM
Quote:
Part number? High-mount fan version?
chetspencer 08-22-2013 08:14 AM
Quote:
Sorry don't have it handy, but you need to make sure and check to see what size shaft you have now or the pulley won't fit.
