fuel leak
hello, i have a new fuel leak!first it was the fuel filter cap cracked. replaced that and gasket then still leaking,see fuel sensor leaking after warmed up (swelling).bypassed it nut still leaking!!!can anyone tell me where else these engines have problems before i just throw in the towel and go to mechanic???
Dont give up yet. We can get you all fixed up. Fuel is know to leak on these in various places in the valley. Try to get the already leaked fuel cleaned up and then start it and watch for leaks. If its the fuel restriction sensor leaking, it can be taken out and replaced with a plug. Check the lines from the pump to the bowl. They can crack and start leaking. If you have alot of miles on it, its probably a good idea to take the fuel bowl out and replace the orings. All these parts can be bought at riff raff diesel.com or diesel orings.com.
Originally Posted by stainlessstroker95
(Post 13284080)
Also agree about to take the fuel bowl out and.... :-X22 :-drink |
Can also leak out of the back of the heads and front of the heads but if your valley is full its probably one of the above suggestions.
well the filter lid and o rings were replaced when i first saw the leak and the fuel restriction sensor was plugged at the same time. so today i replaced all the rubber hoses but i am wondering how to purge the fuel system since everything drained out?
Fill the bowl up and fire it up.
okay thanks
