Need info on 1958 M100 Vin
My uncle, father and I are trying to gather as much info as we can about the truck, (it was my grandfathers and we are planning to restore) right now the catch is my uncle can't find the vin.
Through some detective work I've managed to find a number on the glove box plate, I think I've decoded most of it, I'm hoping its right.. Number is 5991010WK12774 If what I've done is right the info goes like this 5 ? 99- Styleside 10-M100 10-110 Wheelbase W-Build year K-Oakville Plant 12774- Sequence number. So, I'm wondering if the vin actually starts with a M10 or a F10. I would think F10 so, the vin should be F10*8K12774 The star would be engine size right ? Which is what the 5 at the start of the number should be ? Anyone have any ideas ?? How far off am I ? Thanks. |
That's an interest number you have come up with. The NumberDummy will be your best bet for explanation. Post all the info you can find.
Sadly, that's all the info I have here.
The truck is 3 hours away from where I am. What I have is what was on the data plate on the glove box door. 5991010WK12774 AGD 99 3 LD 4.11-1 M100 110 5000 The info I have seen says that AGD is Trim package 99 is Paint which I've found to be Burgundy 3LD is 3 speed Light Duty Trans 4.11-1 seems to be Gear Ratio M100 is model 110 is wheelbase 5000 is GVW I've been told it is a 6 cyl, and my research says that the only 6 was there is a 272 CI 2 Barrel Carb with 153 Horsepower So I'm hoping that my hours jumping from fan page to fan page is accurate and that what I've seen here so far actually pans out the way I'd like it to. :) |
There are several Mercury owners on here and the 49-56 forum that may have info to help decode. But I don't think the Ford info translate to Mercury.
