Ford Truck Enthusiasts Forums
-   1994.5 - 1997 7.3L Power Stroke Diesel (http://www.ford-trucks.com/forums/forum170/)
-   -   The new truck broke down - need advice quick (http://www.ford-trucks.com/forums/1251543-the-new-truck-broke-down-need-advice-quick.html)
cowmilker08 06-24-2013 05:01 PM
I lost power steering and the brakes, so I figured the serpentine belt came off. Pulled off the road, and sure enough the belt was off.
It was caused by the vacuum pump pulley breaking. I've never seen anything like it.
Question is: I can get a pulley for about $25 or a new pump with the pulley on it for $125. Is it a worth $100 to change the pulley or is it a really bad job?
DarkStarMedia 06-24-2013 05:06 PM
the pulley will only break when the pump locks up...
buy a replacement pump and belt.
Richard
cowmilker08 06-24-2013 05:33 PM
The pump is not siezed. Its almost brand new. I'll post some pics. It looks like the pulley was just defective. It did ruin an other wise good belt which sucks.
cowmilker08 06-24-2013 05:43 PM
http://www.ford-trucks.com/user_gall...id=255322&.jpg
richdawg 06-24-2013 06:33 PM
It seems really odd that the pulley would just break off, do you still have a
http://i40.tinypic.com/dzcdwp.jpg
richdawg 06-24-2013 06:35 PM
Seriously, I would be taking that thing back and raising some Hell }>
ReBilld 06-24-2013 07:33 PM
If the pump is new, then maybe whoever changed the pump damaged the pulley, like cracked it trying to pull it incorrectly. Looks to me like they might have tied to use a gear puller on the outer edge of the pulley and cracked it, then pressed it back on the new pump. I'd try the pulley first.
strokin'_tatsch 06-24-2013 07:44 PM
Change the pulley first..
It's not worth $100 to have anyone change the pulley. You can do it yourself very easily. Takes me about 10-15 minutes. I have a bunch of pics on my photobucket that I can put in here if you need to see how to change it. All you need is some wrenches, a socket/breaker bar for the tensioner, and the pulley puller/installer tool. The puller only costs like $20 IIRC at parts stores.
ReBilld 06-24-2013 07:54 PM
Yes definitely use the correct tool! This is the puller I have....Performance Tool Power Steering Pump/Alternator Pulley Puller, Model# W87020 | Specialty Tools| Northern Tool + Equipment
And this is the installer........Performance Tool Ford Power Steering Pump Pulley Installer, Model# W87021 | Specialty Tools| Northern Tool + Equipment
They work great!
madpogue 06-24-2013 08:12 PM
Yup, it's starting to add up -- fairly new pump, pulley most likely transferred from previous pump, pulley fails --> pulley was removed by a jaw puller. I've seen it mentioned at least once that if you use a jaw puller on a p/s or vac pump pulley, it will break.
I've used this tool from Harbor Freight - Pulley Remover and Installer Set - both to remove and install the pulley on a vac pump R&I. AFAIK most FLAPS have one like it to lend out.
strokin'_tatsch 06-24-2013 08:18 PM
I got my installer and puller in a kit from Advance Auto Parts. Came with both the puller and the installer in one kit.
ReBilld 06-24-2013 08:28 PM
I bought mine at a Western Auto parts store. They weren't in a kit together though. They were hanging right beside each other in separate packages. I think I paid more for mine than what was on the Northern Tool link I posted though :-X18
cowmilker08 06-25-2013 11:11 AM
Thanks guys. The pulley should be here today. I am going to either rent/buy a puller from the parts store.
Travis, hopefulley I can figure it out myself, but I'll let you know if I need those pictures.
Also, The cap for the PS pump was either knocked half off or else blew half off. I don't know what's up with that. But now i have a bunch of PS fluid to clean off the engine.
OldWoodsDiesel 06-25-2013 03:07 PM
you can also get a cheap installer here:
McMaster-Carr ...except you have to buy them in packages of 50 :) (though you can buy them one at a time at your local hardware store, probably)
in other words - a bolt and some washers works just fine for doing the re-install. the thread on in the pump shaft is 3/8-16. an 1.5" screw and some washers to shorten in up when the screw bottoms in the threads is all you need.
pulling on the hub instead of the rim of the pulley makes a lot of sense, though!
ReBilld 06-25-2013 05:01 PM
When the belt broke, the power steering pump quit pumping, and when you turn the steering wheel without the pump pumping, it forces the fluid up and out the cap. It should be fine when you get the belt back on. Just remember to check the fluid level after it's warmed up.
