2004-2005 Ford F250 Truck Super Duty 4WD Front Wheel Bearing & Hub Assembly Rear Wheel ABS
CHECK HERE FOR GREAT PRICES 2004-2005 Ford F250 Truck Super Duty 4WD Front Wheel Bearing & Hub Assembly for Models with Rear Wheel ABS & Single Rear Wheels (SRW) Pair
FREE SHIPPING IN THE LOWER 48 STATES!!! http://static.1aautoimages.com/parti...00024/main.JPG Specifications: Comes as a PAIR Fits both LH (Driver Side) & RH (Passenger Side) FRONT 4 bolt flanges Direct replacements Replaces dealer part numbers: F81A-2B663-EF, F81A2B663EF, F81Z-1104-ED, F81Z1104ED, F81Z-1104-EE, F81Z1104EE, YC35-2B663-EA, YC352B663EA, YC35-2B663-EB, YC352B663EB Fits 8 Lug Wheels Studs already installed Built to strict quality control standards Correct for 4WD Super Duty (SD) trucks with Rear Wheel ABS , SRW (Single Rear Wheels), course thread studs, & 13mm thick hub flange Will NOT fit trucks with 10mm thick hub flange because it will cause the front brakes to drag Note: For 1999 models you can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch pillar that the door closes on. Quality You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us. You don't want to be delayed by a defective part. 1A Auto wheel hubs & bearings are all tested prior to shipping. Fit Guaranteed These hub & bearing sets will install just as your originals do. You can use your existing hardware. Save time and money with direct fit hub bearing assemblies. No trips to the auto parts store or extra time trying to match up and press bearings. Hub installation is a degree more difficult than changing a tire on most vehicles. Value Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill. 2 Year Warranty This item is backed by a 2 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. This part replaces: Reference #: 515021 x2 |
