Too much Vacuum advance?
Ok! With the help of some folks on this forum I was able to unfreeze my mechanical advance. The mechanism was frozen partly advanced, so I had to re time it. Now it's running like crap with the vac advance connected. The advance is way past the timing marks. It put an allen wrench in the vac to adjust, but it doesn't engage with anything. Seems to be happy without the vac advance. I don't drive it alot so I'm not too concerned about gas mileage. Is it worth messing with or should I just leave it disconnected?
460 duraspark II, D3V Heads |
After more playing around, It runs rough when not under load (just cruzin at 40 or reving the engine in the driveway). It's like it gets too much vac advance when not under load. I don't get the same problem when I disconnect the vac advance.
