1955 f350 dually
Just purchased a 55 f350. It has 8 lug wheels. Everything I'm finding says the 8 lugs were on the 250's. vin tag starts off f35. Where the 8's an option?
No, probably was converted. Does the back match the front? Stu
Yep front is also 8 lug.
Welcome to FTE....
We need to see pics of your F350, please |
Originally Posted by Fiddy5
(Post 13184984)
I will put some pictures up this afternoon. I have caught the fever, I'm in the middle of a frame up on another 55 f100. This truck came along and I couldn't pass it up.
Welome to FTE. Please get a close up shot of the front hub. Does it have a 'Toledo adapter' on it? I have another I want to convert, but the adapters I used are quite expensive purchased new, and requires a machine shop. I'm hoping it has a front axle from something else under it, or perhaps a hub from something else that will mount on our f350 spindle. The rear is easy. I'm thinking you have a later model rear axle. Fever? Sometimes I lay awake at night for hours engineering my next phase. It only gets worse.......
Didn't get a chance to upload the pictures yet. Spent yesterday re-wiring the tail lights and going over the motor. Seems to be a 1964 model 292, or at least that's what the tag on the carb indicates. It smokes a little after it gets warmed up so I'm thinking it needs a ring job...
Could we see some pictures? Here is how.
Quote: Originally Posted by 76f350spercamprspeal Welcome to FTE, Best Damn Forum EVER! ------------------------ Here's How to Post Pictures: 1. Login to FTE. 2.Click User CP (In the Top Left Hand Corner) 3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That. 4.Then, Click Add Album, Enter a title, and description, if ya want to. 5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time) 5. Click Upload. 6. Add a description to the individual pictures, then click save. 7. Add more files if ya want. 8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG]) Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post. You can add up to 30 Images in one FTE Post. If, Ya need any help, Don't hesitate to ask. Quote: Originally Posted by old_dan You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album. It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available). Quote: Originally Posted By Jolly Roger Joe Welcome to FTE! Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE. While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this: The best photos and videos | Photobucket Copy that highlighted info (right click / copy). When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens). Your pic will be placed in the post. Hope that helps. Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html |
I'm back
Been to long. Completely rebuilt the 292 after pulling the valve covers off to adjust valve lash and couldn't see the rockers for the gunk! Nice and purdy now with plenty of good CLEAN oil making its way up top. The front axle appears to me to be from a 55 or so 250 truck and the rear is a 74 or so Dana 60.
:(Links don't work Bud:(
I love the Texaco signage And the Lab.
