A couple of vins/warranty plates i need decoded
I am looking for a 5 spd with OD trans mission from a 79 'ish F600..I have came across 2 trucks..but not sure if they have od.
The vin for the first is F60ccdk2492...trans code 4 The second one is F61ecx41510...trans code 0 Thanks for all the help!! |
Originally Posted by Dieselzuk
(Post 13168495)
I am looking for a 5 spd with OD transmission from a 79 'ish F600..I have came across 2 trucks..but not sure if they have od.
The vin for the first is F60CCDK2492...trans code 4 / The second one is F61ECX41510...trans code letter O F61 = F600 2WD / E = 361 2V or 4V FT engine / C = Oakville Ontario Canada Truck Assembly Plant / X41510 = 1977. O refers to two different 5 speed transmissions: Fuller model T905B 5 Speed Direct or New Process model 542FL 5 Speed Direct. |
Thank you sir!
