Adjustable Pedals Not working
Hi all,
I just replaced the battery in my 07 EL with power seat and pedals. Everything was working fine prior to changing the battery. Now the power seat is intermittently pausing or not working when I put the key in the ignition and the wife discovered that the pedals are not adjusting. Any known solutions for this? If someone knows the correct fuses to check and the location of the fuse that would be great too. Thanks |
Does the button for pedal adjustment work? Have you checked all the fuses?
The button is not working. Everything was working prior to battery being changed.
Check fuses
Now everything is working as it should which means this has become an even harder to resolve intermittent problem.:-arrgh
