Ford Truck Enthusiasts Forums
-   General Automotive Discussion (https://www.ford-trucks.com/forums/forum135/)
-   -   Truck Wont Start BUt Battery good (https://www.ford-trucks.com/forums/1239820-truck-wont-start-but-battery-good.html)
lditges1 04-27-2013 10:09 PM
I have a 2000 Ford F250 7.3 when I slam the hood it will power up but as soon as I plug the key in the truck immediately dies. I tested the battery is good. Please Help stuck in midland if I cant figure this problem out.
Furyus1 04-27-2013 10:49 PM
Welcome to FTE.
How did you test the battery - was it tested under load?
ford2go 04-28-2013 12:18 AM
Please give a few more details --
Sounds like you 'somehow' get it started when you slam the hood -- are you using your remote?
Then when you put the actual key in it dies. Do I have that right?
If it's a key that works with the anti theft, maybe it's not being recognized. I know almost nothing about those systems, but I would assume that a dealer could check to see if the chip in the key is working.
Good Luck,
hj
galaxie641 04-28-2013 11:55 AM
Pull the connections off, clean and reinstall, also make sure the cables aren't rotting out under the insulation.
